Old 07-30-2010, 02:04 AM   #1
markhat250's Avatar
Trader Rating: 65 (100%+)
Default What's the best hi-Temp bearing lube?
Ok...I am an off-road guy, but I figured I'd come here cuz these on-road cars get hot and take a beating!!!!
What are you guys using or what is your routine for keeping your bearings not failing, and running ultra smooth in your drive trains?
I typically use contact cleaner, then lube it with Marvel Mystery Oil. I think this attracts a lot of dirt. So I was going to switch over to Tri-Flow which is what all the Lance Armstrong cyclists use.
What are your tips? What are YOU using? Thanks.
markhat250 is offline   Reply With Quote
Old 07-30-2010, 03:27 AM   #2
gfilos's Avatar
I think that in off-road applications guys use grease instead of oil. In on-road
applications we use oil. I personally clean the bearings with an ultrasonic cleaner device,
and use serpent premium lube to lube them. Just 1-2 drops at each bearing.
Also serpent bearing lube is good, i just found that premium lube is a bit thicker
(you can find them now under Xceed brand). After 2-3 races i take them apart and clean them.
Are your bearings metal shield or rubber shield? we mostly use rubber shields in which is very easy
to remove the rubbers and clean them.
Some people do not like the procedure of cleaning bearings (i dont like also) and throw away bearings
that dont run smoothly. To do this you have to find bearings at an affortable price. I have heard that
abec35 are good bearing at a great price.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 07-30-2010, 03:40 AM   #3
RayJ's Avatar
Keep your bearings clean is the surest for long life. As far as lube.... buy yourself a bottle of Mobil One..... and you have enough oil for life! Spending a lot of money on bearing oils really makes no sense. One trip around the track and the bearings collect dirt. One way bearings do require there own special oil, and clutches as well.
RayJ is offline   Reply With Quote
Old 07-30-2010, 04:23 AM   #4
gfilos's Avatar
one bottle of special lube for rc bearings (such as serpent bearing lube) costs about the same with a bottle of
mobil one (or less) and lasts quite a lot (many years) if you consider that you
apply a drop on every bearing. So i dont see that cost is much.
Old 07-31-2010, 04:46 AM   #5
FREAKAH's Avatar
I use a 80/20 mix of these oils....
Sin Bearing Oil
Militec-1
80% Sin, 20% Militec.
I like the Sin oil because it's a very light oil. The Militec-1 oil adds a little more viscosity.
After years of trying all kinds of bearing lube, I have noticed that bearings get grittier faster when using thicker oil or grease. My theory is that the thicker oil/grease doesn't allow the balls in the bearing to roll, especially is situations like sudden heavy acceleration. Rather, the balls are slipping/galling against the bearing races when under these high load situations.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 08-09-2010, 11:51 AM   #6
asw7576's Avatar
tamiya ceramic grease, nuff said.
Old 08-21-2010, 10:46 PM   #7
modified763's Avatar
Trader Rating: 73 (97%+)
After you clean them, Boca makes a great bearing soak. Soak them overnight and your good to go.
Team Hot Bodies, Team O.S.Engines and Glow Plugs, Team AKA Products,Team Boca Bearings, Team O'Donnell Speed Blend Fuel, Team Upgrade RC, Tesla, Billy Oceans
modified763 is offline   Reply With Quote
Old 08-22-2010, 07:45 AM   #8
Believe it or not I have used a lube specifically made for guns. Guns heat up considerably and have vicious metal to metal wear and contact. Lubes are typically thin and very resistant to burn off etc. I've used a product called Weapon Shield before. It bonds to metal parts and protects against wear, corrosion, it is also a good cleaner, very slick lube, and doesn't attract dirt like grease.
If you prefer a grease the company makes a product called Lithi-Shield that is made specifically for bearing applications. It has the same properties as the oil products but is available in a tube. Grease tends to attract dirt and particulates more than an oil, but will last longer in my experience.
http://www.steelshieldtech.com
Dredd is offline   Reply With Quote
Old 08-23-2010, 09:55 AM   #9
lil-bump's Avatar
Trader Rating: 83 (100%+)
removed
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
