Old 07-30-2010, 11:21 AM   #16
wingracer's Avatar
Trader Rating: 24 (100%+)
Originally Posted by gfilos View Post
ahh, ok thanks for the info. In fact when i want to change a pinion i am
facing this problem with pinions being too tight. I guess i have to find
this stuff, but i dont know how to ask it? can you help by posting a link?
Any auto parts store and many hardware stores should have anti-seize compound. It is common on autos for exhaust manifold bolts, o2 sensors, etc. to make them easier to get out. Just ask, they will hook you up.
On a side note, I just put the pinions on finger snug (not tight) and put some wheel bearing grease on the threads (same stuff I use on thrust bearings). Probably not as good as anti-seize but has worked fine for me.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-30-2010, 12:39 PM   #17
gfilos's Avatar
thanks a lot wingracer
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 07-30-2010, 02:35 PM   #18
avs
avs's Avatar
interesting, since the late '90's i have always put the pinions on tight with threadlock. my first experience with 1/8 scale (a NEO) had pinions coming loose.
at the time the oneway bearings were a reliability issue, and there was a fair amount of drag from the standard bearing oil or grease used on the oneway bearings which i presume was the culprit.
this was all before using mineral oil was popularized, and serpent introduced a specific 'oneway lube'. maybe i need to 'lighten' up.
Tony Shimko
avs is offline   Reply With Quote
Old 07-30-2010, 02:39 PM   #19
wingracer's Avatar
I have never had one come off. EVER.
Team Shepherd USA
