Old 04-02-2002, 11:11 PM   #1
Buster Bennett's Avatar
Send a message via AIM to Buster Bennett
Default **** Serpent Impulse Thread ****
As promised!
Buster Bennett is offline   Reply With Quote
Old 04-04-2002, 04:11 PM   #2
Default Front Belt Stripping
I installed a front one-way, and am aware the it puts more stress on the front belt. Because of that I added the aluminum mid-block and stepped up to a 5mm wide front belt, and the thing still strips. Any ideas on how to make the front belt last longer.
Any suggestions are welcomed.
jvjave
jvjave is offline   Reply With Quote
Old 04-04-2002, 04:46 PM   #3
Motorman's Avatar
replace the 16 tooth mid pulley with a paris alumunium pulley. it will help alot.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 04-04-2002, 05:04 PM   #4
Default FPS Diff
I'm running a front one-way w/ and adjustable fps diff in the rear. What would the afftect be if I tightened it close to locking? Would on power steering improve? or will it push harder? Need some physics lessons here.
jvjave
Old 04-05-2002, 07:05 PM   #5
GregH's Avatar
Send a message via AIM to GregH
Default Re: FPS Diff
jvjave
I think the solid will take away rear traction in the turns and give more forward bite. While the oneway will pull the car through the turns faster with more corner traction. There real tricky to drive but are real fast if traction is good. If I'm wrong please step in.
GregH is offline   Reply With Quote
Old 04-07-2002, 07:27 AM   #6
sneezer714's Avatar
GT4-R Terror you are right i have my impulse set up that way and it handles great add a lola body and foam tires and your impulse will rock
sneezer714 is offline   Reply With Quote
Old 04-09-2002, 01:26 AM   #7
... just wondering how it would handle with a solid front and a rear ball diff (not the FPS)? ... has anyone tried?
Is it possible to make it handle really tight - like good steering in and out of corner and on and off the throttle ( on asphalt with good amount of rubber laid down) ... ?
stik is offline   Reply With Quote
Old 04-09-2002, 12:20 PM   #8
sneezer714's Avatar
stik
BEFORE I HAD THE SOLID REAR AND ONE WAY UP FRONT I WAS USING ( SOLID UP FRONT AND GEAR DIFF. REAR ) WHAT I FIND OUT FROM THAT SETTING TO THE ONE IM USING RIGHT NOW IS THAT I HAD TO USE THE BRAKE A LOT. NOW IM MAKING FASTER LAP TIMES AND USING LESS BRAKE OR NOT BRAKE AT ALL, IS LIKE DRIVING A 1/8. I HAD TO CHANGE THE WAY I DRIVE, BUT I LIKE IT BETTER THIS WAY....
Old 04-09-2002, 02:06 PM   #9
Are there floating rear body mounts for my serpent impulse streetspec?
~Brandon
LiLRCLoUiE is offline   Reply With Quote
Old 04-09-2002, 09:43 PM   #10
sneezer
that's what i am running now - solid front and gear diff rear. I like how much better it corners on power. i'm giving the oneway front/ solid rear a thought but i want to find out first how the rear ball diff handles from you guys who have tried, because rear ball diff is still different from gear diff with light (or even without) oil.
thanks for the positive input on the oneway front/solid rear setup. i've heard alot of positive feedback on it. but as of now, i'm still scared of losing front break. i guess sooner or later i'll have to give it a try.
Old 04-14-2002, 01:44 PM   #11
~Brandon
yes. youc an find it at ashfordhobby.com
SER 808150 Body Mount Set GTP EV2 $24.75
i believe thats it.
Impluse Guy is offline   Reply With Quote
Old 04-14-2002, 01:58 PM   #12
Cool thanks
~Brandon
Old 04-14-2002, 04:34 PM   #13
no problem
Old 04-14-2002, 05:15 PM   #14
AE_Racer's Avatar
Send a message via AIM to AE_Racer
Can you guys tell me what I will need to run the Lola/GTP bodies? and will the Yokomo Lola or GTP body work? Thanks
AE_Racer is offline   Reply With Quote
Old 04-14-2002, 08:35 PM   #15
you can run either one you wish. i believe you just need to get an impact front bumper and dremel it to fit( its too wide) and you will need to get the rear mount , the part# is on my last post.
Serpent Impulse Pro coastaltony R/C Items: For Sale/Trade 4 10-11-2004 04:50 PM
Serpent Impulse Pro xxxssportracer R/C Items: For Sale/Trade 1 04-30-2003 09:05 AM
Serpent Impulse V9 InitialD Nitro On-Road 60 01-06-2003 06:48 AM
Serpent Impulse Post Your Pics Thread 1.0 Raytrix Nitro On-Road 0 03-14-2002 06:33 PM
