Old 04-15-2002, 07:27 PM   #16
AE_Racer's Avatar
Send a message via AIM to AE_Racer
thanks, do you know where I can order Serpent parts online? I have no shops close that carry Serpent parts...Superior is a 3-4 hour drive...
AE_Racer is offline   Reply With Quote
Old 04-15-2002, 07:33 PM   #17
to get the mounts try ashfordhobby.com
for other things try
www.brucknerhobbies.com
www.atomichobbies.com
thoes are just in general.. if ya need more let me know.
is anyone running FPS rear diff in their impluse? if so how much did you get it for and do you like it?
Impluse Guy is offline   Reply With Quote
Old 04-16-2002, 01:49 PM   #18
AE_Racer's Avatar
Saved me again....Ok, I know im asking lots of questions but, what engine do you suggest? I was thinking RB X-12...
Old 04-16-2002, 03:40 PM   #19
AE_Racer: go to www.myrcworld.net, select "columns" and then
Tenthoff's article on mounting GTP/Lola bodies on the Impulse...
Has photos of mods and completed setup...very imformative.
BTW, Tenthoff works for and races for Serpent.
jd300zxtt is offline   Reply With Quote
Old 04-16-2002, 06:27 PM   #20
AE_Racer's Avatar
WOW! Cool man, thanks alot!
Old 04-16-2002, 07:40 PM   #21
sup guys....ran my impulse at the local track today...the thing keeps slipping. what should i do? when i go into a turn, the back just spins forward. i'm using 40 shore tires all around. a friend of mine who's good with r/cs says i should try the stiffer springs up front first. also i've been hearing from a lot of people that i should just cake in the diff grease they give you.
Turtle On Nitro is offline   Reply With Quote
Old 04-16-2002, 08:14 PM   #22
sorry im not to good on engines.
Old 04-16-2002, 10:07 PM   #23
vthondaboi's Avatar
Send a message via AIM to vthondaboi Send a message via Yahoo to vthondaboi
I had the RB X12 and it was a great little engine. Passed people on the straightaway like there wsa no tomorrow. Besides modified tuner engines it's probably the second fastest ROAR legal motor. Plus it's a nova so you know you're getting quality.
vthondaboi is offline   Reply With Quote
Old 04-16-2002, 11:07 PM   #24
try either softer springs in the rear or harder in the front for more rear traction.. and if that doesnt help much you might try heavier wt oil in the rear diff.
Old 04-17-2002, 07:59 AM   #25
Eddie M's Avatar
also try reduce the rear droop setting (move up 1 or 2 mm on your droop gauge from your current setting) to minimize weight transfer to the front of your car.
Eddie M is offline   Reply With Quote
Old 04-17-2002, 10:54 AM   #26
InitialD's Avatar
Originally posted by Impluse Guy
yes. youc an find it at ashfordhobby.com
SER 808150 Body Mount Set GTP EV2 $24.75
i believe thats it.
Just to let other people know, using the 808150 body mounts, you will be forced to loose the 7mm spacers, assuming you run a PRO kit that is. This is mentioned in Milko Tenthoff's article.
So best is to go with the 808143 rear carbon bodymounts and you will still be able to keep the 7mm spacers.
Old 04-18-2002, 01:17 PM   #27
N1
guys check this out and tell me what you think.LINK
N1 is offline   Reply With Quote
Old 04-18-2002, 04:33 PM   #28
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
I'm thinking about getting and Impulse Pro, I'm not familiar with "Gear Diffs" and I was wondering what the advantage or disadvantages are.
Would it be in my interest to upgrade to the Impact's Ball Diff? And if so, would I need to modify anything else?
ChristopherKee
ChristopherKee is offline   Reply With Quote
Old 04-19-2002, 11:53 AM   #29
Exclamation re: christopherkee
i have the serpent impulse pro and you dont need to upgrade anything it is good stock there are disavanteges to upgrading to the impact's ball diff its not worth it though!
FactoryteamTc3 is offline   Reply With Quote
Old 04-19-2002, 11:56 AM   #30
it isnt good to upgrade keep stock and youll be happy dont do what the tc3 does thanks
Serpent Impulse Pro coastaltony R/C Items: For Sale/Trade 4 10-11-2004 04:50 PM
Serpent Impulse Pro xxxssportracer R/C Items: For Sale/Trade 1 04-30-2003 09:05 AM
Serpent Impulse V9 InitialD Nitro On-Road 60 01-06-2003 06:48 AM
Serpent Impulse Post Your Pics Thread 1.0 Raytrix Nitro On-Road 0 03-14-2002 06:33 PM
