Old 07-27-2010, 07:06 PM   #16
Originally Posted by VA_Racer View Post
here try these, they are cheap and I havent had any problem with them http://www.avidrc.com/shop/index.php?l=search_list&s[title]=Y&s[short_desc]=Y&s[full_desc]=N&s[sku]=Y&s[match]=all&s[search]=thrust+bearing
$3ea, good price. ill order a few tonite.
anyway question; would a blown bearing make my clutch slip and heat up?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 07-27-2010, 08:58 PM   #17
Originally Posted by azcau View Post
will this work.
http://www.amainhobbies.com/product_...x10x1mm-Washer
Old 07-28-2010, 12:23 AM   #18
Roelof's Avatar
Send a message via ICQ to Roelof
The thickness of the bearing becomes smaller what wil give a bigger gap and that causes slip......
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-28-2010, 05:09 AM   #19
can i also ask why capricorn.
1 thrust plate is 5.2mm and the other is 5mm?
will any 5mm thrust bearing work? or do i need the specific one (5.2 & 5.0mm)
Old 07-28-2010, 06:02 AM   #20
Roelof's Avatar
The disc with the 5.2mm hole must be mounted towards the clutch so the 5mm shaft can run free from it.
Old 07-28-2010, 06:47 AM   #21
thanks, i ordered 3 thrust bearings from avid.
i wonder if it comes with 2 diff size plates.
Old 07-28-2010, 03:27 PM   #22
gfilos's Avatar
let my give you an advice. Keep with stock things. Dont mess brands on
one thing or on the other. If your clutch is properly measured and well
maintained trust me you will never have a thrust bearing failure.
Or almost never I never had the past 3-4 years. Just my opinion
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 07-28-2010, 03:58 PM   #23
all thrusts come with two diff size washers i believe the one with the bigger hole goes toward the motor if u get it backwards it will destroy the bearing quick as i have found out the hard way but i use the kyo thrust on my cap clutch with no probs at all, and thats with the bigger kyo washer on the inside and the cap smaller washer on the outside so u can mix stuff up with no problems
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 07-28-2010, 09:52 PM   #24
i dont think thrust bearings would make a difference, as its a bearing.
i wasent prepared to pay $12 + $13euro ($25eu) for a thrust bearing to be posted to australia until i figured out why i was blowing bearings
Old 07-29-2010, 05:04 PM   #25
your talkin to a guy with nt1 diffs in a kyo i think hes past the point of trin not to mix brands up
Old 08-08-2010, 10:38 PM   #26
flynia's Avatar
I've had no end of issues with TM thrust bearings. I have replaced my dodgey TM one with a Serpent Thrust Bearing and it is working like a charm!
Team Magic G4RS 2009 / K Factory K1007-3 Body Shell
RB T10-RC Engine and EFRA 2659 Pipe Set
Hitec Servos - HS-7775MG (Throttle) and HS-7965MG (Steering)
LRP LiPo RX PACK AAA HUMP 1700 RX 7.4v with MuchMore MRG-5A Regulator
KO PROPO EX-10 EURUS Transmitter with KR-407S Receiver
flynia is offline   Reply With Quote
Old 08-09-2010, 01:24 AM   #27
u forgot serpent shocks... lol.
also running random mugen/xray rear belt lol.
Old 08-09-2010, 01:47 AM   #28
blis's Avatar
Default I guess something's gotta give.
I think we overlook the clutch itself and the role the Thrust bearing plays. I Use TM thrust bearings and they work well for me.. I suppose you also have to consider the spurs, the clutch bearings, pinions, shims too.
When the clutch engages, everything becomes static and the thrust bearings bear the load of the engaged clutch, if the thrust bearing is arse about ie plates wrong way, then perhaps a chance of bearings wearing the cage and balls fly everywhere.
On power then off power and clutch would be at a state where the problems arise as the clutch bell freely spins on a crankshaft with bearings, shims and retainers. Spurs and Pinions, too much end play and things could shudder... very bad... very bad
When at idle, an inspection of clutch never hurts... seen a few clutch retainer screws fall out a few times too.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
