Old 05-28-2004, 07:21 PM   #1
Send a message via AIM to AtomiK
Default STS RS3 on HPI R40
Can you fit that engine on that car? Also, can someone give me direction on how to start my car with a starter box? I tried doing it, but then the flywheel wouldn't spin. Also, is this car good for like casual driving, I don't really plan on racing it.
AtomiK is offline   Reply With Quote
Old 05-28-2004, 08:02 PM   #2
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
it will fit in your car , as for the direction it's all depends on what kind of starter box you are using...
trying to start a new STS engine can be a pain in the a$$...loosen up the glow plug a little when trying to start the engine , be really patient..i would recommend a 1/8 starterbox w/ 12v gelcel when trying to fire up for the first couple of times..
good luck
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 05-28-2004, 08:03 PM   #3
I have this starter box, would it work? Ofna Starter Box
Old 05-28-2004, 08:06 PM   #4
Tag
Tag's Avatar
sure it will work, you might have some trouble starting the engine for the first couple of times but once you get it started , breaking in for a few tanks, it should be fine..
Old 05-28-2004, 08:26 PM   #5
would the ofna ld3 also work with the engine?
Old 05-28-2004, 09:01 PM   #6
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
yes it will
Old 05-28-2004, 10:21 PM   #7
Another question. Would the Futaba S3305 servo work with the airtronics MX-3 reciever?
