Old 07-05-2010, 08:57 PM   #1
NitroChef tC3's Avatar
Default help.... ntc3 front diff housing prob...
does anyone know of an aftermarket diff housing for the ntc3... or a fix on the ae factory ones... the problem is that the threads in the diff case are plastic and stripping then the screws have nothing to hold.. seems to be a common prob on the car... thanks
NitroChef tC3 is offline   Reply With Quote
Old 07-05-2010, 10:16 PM   #2
nitrodude's Avatar
Get 3mm screws, they're just big bigger than the 4-40s, thats what i use to do when I had mine. Dont overtighten.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-06-2010, 02:41 AM   #3
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
"the fix" is what you need.
http://www.rctech.net/forum/nitro-ro...nitro-tc3.html
if you do a search youll find its just screws, nuts and shims.
should be pretty cheap too.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 07-06-2010, 09:40 AM   #4
Default the fix...
do you know if they still sell the fix and where,...,, also do you know of any aluminum diff housing... ive seen them on a picture of someones car... idk
Old 07-06-2010, 12:17 PM   #5
Oasis's Avatar
Trader Rating: 36 (100%+)
RD Logics makes them, they do fix the problem and they don't deform underload, here's a few photos of mine. For club racing the NTC3 is still very competitive..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 07-06-2010, 12:48 PM   #6
Oasis's Avatar
The chassis is a 4mm and it's not really any more weight than the stock, and theirs not much flex, the front shock tower is 5mm and the suspension mount is aluminum, no flex. The car is really fast and it holds up quite well, handles great. It "hangs" with the RRR's and all the other TC's, I honestly don't think I would be any faster with a different car, I've been using a NTC3 for 7 years, I'm use to the way it handles....all the aftermarket stuff is from RD Logics..
Old 07-06-2010, 07:07 PM   #7
Default Aluminum diff
So do yo think I should go with something like the fix or with the aluminum ???? Thanks man.. Your car looks great.. I love mine..
Old 07-06-2010, 07:31 PM   #8
Oasis's Avatar
I thought the aluminum diff cases were a better fix than the fix, they do cost more and I didn't really like the powder coating so I sand blasted mine, and the bearings did not fit great but a little work with a dremel made everything right..I do think that RD still makes them.
Old 07-06-2010, 09:53 PM   #9
Default rd logics diff cases...
were they made for the ntc3 or another car.. they had some but not for the tc3.. i will email them and maybe look on ebay.. let me know of any other option... thanks..
Old 07-06-2010, 09:57 PM   #10
Oasis's Avatar
The ones I have were made for the TC3, but the TC4 uses the same diff cases.
Old 07-06-2010, 10:58 PM   #11
found some but everyone is out of stock...
Old 07-06-2010, 11:04 PM   #12
Oasis's Avatar
Try eBay..
