Old 07-02-2010, 10:07 AM   #1
Default 1/10 Centax Clutch - how to set for very smooth acceleration
Hi everyone,
our track has very tight corners, so thight that you almost get to a dead stop and hard acceleration is wearing out my rear tyres.
What do you suggest, i tried a softer spring and it got a bit better.
I also tried different spacing between the contact patch, went a bit less than .40 and also helped. Unscrewed allmost all the nut but still it kicks a bit.
Help
speed6 is offline   Reply With Quote
Old 07-02-2010, 10:14 AM   #2
CurveTracer's Avatar
What brand car and clutch do you have?
Also a clutch shoe with softer material and lighter flyweights will usually help smooth out clutch engagement.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 07-03-2010, 08:18 AM   #3
Its a Capricorn clutch on a Kyosho Evo 2
Softer material you mean more grip as for the pad?
Old 07-03-2010, 10:42 AM   #4
redsand's Avatar
Send a message via Yahoo to redsand
try harder shoes, so there'll be a little slip.
redsand is offline   Reply With Quote
Old 07-03-2010, 11:53 AM   #5
Harder shoes you mean for the pad grip where contact is made? If yes tried it already
Old 07-03-2010, 12:09 PM   #6
Roelof's Avatar
Send a message via ICQ to Roelof
Are the flyweights mounted over a pin of the flywheel ?
Is so, is the pin pushing or pulling the flyweight. With a pulling flyweight the clutch will become smoother.
Other trick is not the most fancy but works is use a more richer setting on the LSN.
But finally your finger must do the trick, do not open the throttle in one fast moment but open the throttle slowly.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-04-2010, 02:51 AM   #7
Yes they are mounted over a pin but couldn't understand what you meant with pushing or pulling
Old 07-04-2010, 03:51 AM   #8
Roelof's Avatar
Are the flyweights in the way of rotation facing forwards from the pin (pushing) or backwards (pulling)?
Old 07-04-2010, 08:39 AM   #9
here are the instructions just to be sure i understood what you mean, even though i didnt know there where different types of weights like we sometimes did in offroad.
http://www.capricornrc.com/Assembly_...orn_WCE_clutch
I hate Centax clutches!!!! sstupid Nitro On-Road 98 06-18-2007 09:55 AM
Thrust Bearing Question Please TRFTIM Nitro On-Road 26 05-25-2006 07:56 PM
