Old 05-25-2004, 09:35 AM   #76
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Motor choices
Originally posted by Greg Amendola
I've been running the OS 12TR on a short track in my NTC3 and I must say I'm more impressed with this little motor every race. Solid performer, but like all motors, you need to be at the right gearing/roll-out. I've been running against the fastest motors out there and have had no probelm hanging with them.
I guess before you decide to put a heap of cash and power into the car, you might check your setup and gearing for better speed/handling. To many times have I seen people go for the power thinking it will fix everything and then they end up in a lower main than before and having tuning issues.
My suggestion is: save money, have fun. On track with a straight less than 150ft, lock out the two-speed and stick with one gear. For an NTC3 with new tires, I'd suggest 21/54. For tracks over 150ft on the straight, I'd go with 21/54, 25/50.
Having found the right gearing/roll-out/setup, allows my meager 1.2hp motor to pull away from the pack.
I'm in no way a motor expert but talk to other who race in your area, get their advice, get their settings, and go have some fun!
i do too run the OSTR and the best part is when i win a main and the guy that comes in second cant believe it when he sees the engine that i have
Old 05-25-2004, 11:25 AM   #77
rod_b's Avatar
Send a message via AIM to rod_b
Default Re: Re: Motor choices
Many times, these engines with Mega power are overkill for the driver. If you have an engine with "enough" power to match your skills, you'll most often be more successful. I won my first race ever with an OS .12 Hyper engine against Nova C12s and Mugen MT12s.
rod_b is offline   Reply With Quote
Old 05-25-2004, 12:27 PM   #78
Greg Amendola's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to Greg Amendola
Default Durability
Another oversight some people make is that fact that the heavy tuned motors are harder on their cars. I re-check my entire car each week as a practice I follow. It comes from years of running low-wind mod motors in electric. When running stock, I still wrenched as much but saw much lower stress/wear on the car.
I believe this premise applies to Nitro cars as well. I think with motors in the 1hp range, your car bearings, transmission parts, etc should all hold up really well (kinda like a 19T in electic). You run a Muran mod motor, that like dropping in a Reedy KR 8 turn double aat about 18 degrees of timing...watch-out!
I guess my point is you need to consider the effort you need to make to support the hard-core motors, their tuning, the wear factor they cause, regular maintenance, etc. So far for me, no bad bearings, no fried 1-way, no bent dogbones, overall little or no wear to speak of from an OS 12TR.
My advice: If you do purchase a high-end motor, it's worth the time to go through your car, get it in perfect runnning order. Then break-in and set the motor up correctly per the manufactures suggested settings. Then I would document your setup completely and then check the car every other race to make sure the setup is still intact. Maximize your fun and minimize your frustration!
Greg Amendola is offline   Reply With Quote
Old 05-25-2004, 12:46 PM   #79
jhigga15's Avatar
I just got a RB Concept V12, 3 port turbo, I heard that they are good. I still have to put it in the car
jhigga15 is offline   Reply With Quote
Old 05-25-2004, 12:54 PM   #80
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
i run the rossi maranello
mtx3racer is offline   Reply With Quote
Old 05-27-2004, 03:53 AM   #81
jasoncsc's Avatar
Max 12 S5 for outlaw
Collari Sirio 3 port for legal
jasoncsc is offline   Reply With Quote
Old 05-27-2004, 06:18 AM   #82
soc123_au's Avatar
R/C Tech Charter Subscriber
RB V12 Rody 3 port. WEAPON!!!!
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 05-29-2004, 08:39 PM   #83
is it just me or does the mugen x12 engine seem like its just a novarossi ns12s3 just with a mugen name on it and it just cost more?
baller360 is offline   Reply With Quote
Old 05-29-2004, 08:50 PM   #84
B
i have heard the X12 is faster.
B is offline   Reply With Quote
Old 05-29-2004, 10:31 PM   #85
afm
afm's Avatar
MUGEN X12 COMMENTS
"Well, after very very close inspection of the X12 I can say it is longer stroke than the NS12. When I first compared the two it was by eye, when comparing the two with instruments the ports on the X12 and NS12 are in different positions and the crank pin is higher on the Mugen motor".
Uriah Murnan
Murnan Modified Engines
"Iíve got my x12 modified by Uriah Murnan and this thing is ballistic. Iím spinning 35 shore tires a good 30ft down the straight and I have barely gotten the engine over 200 degrees. These engines are screamers. Robbie at Mugen said they used a short stroke conrod with a longer stroke p/s, but they moved the pin on the crankshaft out a little more to get a better power band and let me tell you it worked. Thanks Uriah I love this motor".
Dave
FSTSpeedway
afm is offline   Reply With Quote
Old 05-30-2004, 01:21 PM   #86
can someone post pics of the mugenx12(pics of the piston sleeve etc somthing like that.
Old 05-30-2004, 07:40 PM   #87
GAMBO94's Avatar
And what about the Palmaris Engine
any info on that!!!!!
who has tested it,or seen it in action.....
GAMBO94 is offline   Reply With Quote
Old 05-31-2004, 08:37 PM   #88
GAMBO94's Avatar
Old 05-31-2004, 08:41 PM   #89
Super Moderator
Marcos.J's Avatar
are you coming to the region 4 race?
Old 06-01-2004, 08:15 AM   #90
GAMBO94's Avatar
No,But some of my friends are going,they are leaving tomorrow...hope everything goes well for them
What are the HB guys running at the Cactus Classic DustinR Electric Off-Road 2 03-19-2008 06:49 PM
What top guys are running brushless NR Electric On-Road 33 12-29-2006 12:49 PM
wat electrics are u guys running dirt*hawg Electric Off-Road 19 12-02-2004 04:11 AM
Question for the guys running Xrays... Alvin Singapore R/C Racers 5 05-29-2003 07:27 PM
any TC3 guys running HPI rims?? AndrewtheRCman Nitro On-Road 14 04-30-2003 10:23 PM
