Old 06-05-2004, 12:51 PM   #46
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
the tape looks good the way it is. Just remember (I should have mentioned this before) that when you tape them you want to be able to roll over the seal not against it, if that makes sense. This means that the tape should point towards the rear of the car on the top of the tires.
attached is a picture with some of my truck and more of my driveway.
EDIT:
Originally posted by Smoke21
Corvettecrazy: How is your clutch shoes and bell?
my clutch is pretty new and the clutchbell has a few gallons on it. I need to clean both of them but still have major life left.
corvettecrazy is offline   Reply With Quote
Old 06-05-2004, 05:47 PM   #47
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
Usually you'll burn a clutch up easily when you drift nitro
Smoke21 is offline   Reply With Quote
Old 06-06-2004, 12:06 AM   #48
With the correct setup, you will never burn up your clutch. I never have anyways.
Mister_Drifter is offline   Reply With Quote
Old 06-06-2004, 09:17 AM   #49
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default my taped drift tyre is working BUT.....
hi guys... just to update my DRIFTING SESSION today.
see my taped DRIFT tyre on my HPI RS4 RTR
nice and clean.
mop
mop_iko is offline   Reply With Quote
Old 06-06-2004, 09:22 AM   #50
mop_iko's Avatar
Default taped drift tyre on RTR
the drifting session went okay but i think due to lack of power... or maybe the track surface is too rough, i didnt manage to get the drift that i want. but i can feel by using the electrical tape i can slide big time....
maybe next time i will play on the wide walkway nearby the track.... they use smooth granite surface with some polished granite that definitely allow my tape drift tyre to SLIDE BIG KAHUNA.
next week i post some pic....
hmmmmm how i wish if FUTUREREAL allow us to upload movie files..... that would be cool!!!
before i went into drifting... i always thought if i use electrical tape... i may need a lot of tape due to the tyre wear but after today's session... i found out that the tape sticks very well to the tyre... maybe because the car is not to heavy... so it doesnt give any big loading to the tyre. i guess i can use the tyre for a longer run time!!!!
mop
Old 06-06-2004, 09:33 AM   #51
mop_iko's Avatar
EDIT:
i did realised that i need to tape it in order the tape is OVERLAY each other towards INSIDE other wise it will be STRIPPED easier when your car drift. but then... that time it is TOO LATE for me.. i have taped 2 tyres already... i guess it is definitely TRY and ERROR session for me as always. learn through the hard way.
i do hope this drifting session wont kill my clutch. hehehehe.
and by the way....corvettecrazy... please clean your truck.... i know it is a truck and supposed to be dirty... but yours is too dirty!
mop
Old 06-10-2004, 04:07 AM   #52
mop_iko's Avatar
Default DRIFTING acccessories and bodies
go here:
http://64.70.208.72/speedtechrc/325.html
but the bodies are for 190mm only...
is there any 200mm drifting bodies?
i like the TAIL PIPE... looks real!
mop
Old 06-10-2004, 05:02 AM   #53
compaq888's Avatar
Send a message via AIM to compaq888
what would be drifting if you had a one way in the front and rubber tires all around, but on the back ones electrical tape or just use pvc pipe for the back. I say one way for front is because when you let go off the gas the tires will continue to spin and you will get drifts like real cars, instead of goin sideways half the time like in the video.
I do have a one way in my car, but I'm not about to waste my 3d clutch on a drift
anybody going to try it my way, and i think you will have more control over the drifting using my way
compaq888 is offline   Reply With Quote
Old 06-10-2004, 09:18 PM   #54
Default Re: DRIFTING acccessories and bodies
you could jsut use a HPI silvia ...the silvia is considered a drift car...downside is that there are no body kits on it, jsut a straight silvia.
Old 06-10-2004, 11:05 PM   #55
mop_iko's Avatar
does HPI RS4 RTR car have optional for one way FRONT?
will try to look for the option part. thanks for the NEW TIPS.
no worry about the clutch... coz mine is not centax (the expensive one)... only a normal shoe type.
mop
Old 06-11-2004, 12:15 AM   #56
compaq888's Avatar
I do have the centrax clutch, so I don't want to experiment, all will happen is the front will grip more while the back will have all the power=real drift
Old 09-03-2004, 08:20 PM   #57
mop_iko's Avatar
Default HOW TO MAKE DRIFT TYRE D.I.Y
follow this link
look at first, second and third page.....
mop
Old 09-03-2004, 09:40 PM   #58
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Post
Have you tried buying the drift tires? They sell them at my local HS. They really hard rubber tires with a lot of negative camber to make the rear slide.
ezveedub is offline   Reply With Quote
Old 11-01-2004, 07:11 AM   #59
mop_iko's Avatar
try to see this.. BUT its not NITRO though... shucks...
http://homepage.mac.com/pigeonfarmbo...o.mp4-link.mp4
mop
Old 11-18-2004, 03:46 AM   #60
BrainTeased's Avatar
Do you guys use brakes alot in drifting? cause if you do then a front one way is not the go. as with this unit your car will only have rear brakes, which can lead to nasty 180 degree turns when brake is applied. i've done 360 turns on a straight at my track with worn foams!
I'll be getting my TC3 in 2 weeks in which ill be studying the art of drifting what electric motors do you guys use? someone has told me a 19T is best for drifting. I was hoping a 540 silver can will do. as im getting a ESC with reverse and a 20T motor limit.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Drifting pink panther Australian Racing 113 06-22-2009 11:18 PM
1/10 & 1/18 RC Drifting Speed Demon Malaysian R/C Racers 115 06-22-2009 11:16 PM
Drifting any one???? chinamonkey7 Florida Racing 1 08-13-2006 10:30 PM
Rc Drifting! RCD Electric On-Road 1 08-09-2004 06:51 AM
Anyone ever tried R/C drifting before? RS4_Hits_Wall Wisconsin & Illinois Racing 11 06-18-2002 11:27 AM
