Old 05-20-2004, 06:34 PM   #1
Default Which Nitro Car is tough enough for beginners?
Well I've acquired a NTC3 which has the plastic gear cases.
It had "The Fix" in the rear, but not the front. The front is still pretty loose and could use some help up there.
I'm just starting out, and yes I do hit the car once in a while, but I don't think it's hard enough to do the damage that is being done. Lost a rear and front arm last time and the front gear case is pretty loose.
Do I just swap them out for the alumimum gear cases? Will this add the rigidity up front that I need?
Thanks!
elmar66 is offline   Reply With Quote
Old 05-21-2004, 02:53 AM   #2
Default Gear Case Issues
I wouldnt use the Alum / Metal cases at all .. what you might want to do if its an oldre car ... (front and rear suspensions look about the same) go get the Version 2 rear suspension upgrade .. it works a lot better than the old suspension ... then put "THE FIX" parts that you had on the back upfront ... or .. do the fix that I did ... use the larger screws off of the buggy ahhh part #9644 I think ... and put them into fresh diffcases for teh shock tower mounting .. that way it will hold down the old front and the new rear better ... the 9644 screws are a little wider and a little longer .. so they grab in better ... you might have to drill out a little JUST FOR THE SCREW HEAD ... dont open up the whole thing ... they go in tight and I havent pulled a tower off since ( I did the mod middle of last summer ) ..... as far as the new rear suspension I was forced of the track where I run last weekend ... the car cartwheeled for about 30ft .. broke both rear rims ... not a thing broken on the car itself ... and all the rear toe and camber settings were still perfect ... I just slapped on a new set of tires and ran the next heat ...
have fun racing
E
roddude65 is offline   Reply With Quote
Old 05-21-2004, 07:31 AM   #3
mckrooz's Avatar
Send a message via AIM to mckrooz
The TC3 is a great car for beginners as far as driving, setting up, and working on the car. It's quite possibly the worst for beginners when it comes to fragility. A car that is almost bullet proof is the Kyosho V-One R. I have one for sale if you're interested.(shameless plug) PM me for details.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 05-21-2004, 07:25 PM   #4
BrainTeased's Avatar
Yea the kyosho Vone series are so tough!!! never broken a thing on these cars! i've had 1 VoneS and 2 VoneRR's.!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 05-21-2004, 08:21 PM   #5
Charlie O's Avatar
NITRO TC-3. parts are readily available, and it's easy to work on.
Charlie O is offline   Reply With Quote
Old 05-22-2004, 06:30 AM   #6
It's not about getting the parts, it's about barely touching the wall and replacing the arms all the time...
Old 05-22-2004, 06:36 AM   #7
Tough Decision, trying to decide between two motors. wes95_z28 Nitro Off-Road 19 04-15-2008 07:43 AM
Good tough, fast nitro mini for around $200 lanerbrainer205 Micro and Mini Scales 3 01-09-2008 03:44 PM
Truggies are tough but not unbreakable. Nitroaddicts Electric Off-Road 3 10-15-2006 07:57 AM
Tough Challenges to deal with Tekin Prez Electric On-Road 16 09-11-2006 05:04 PM
Nitro RC Car Guide for Beginners rccartips Nitro On-Road 9 06-28-2003 02:24 AM
