Old 06-21-2010, 08:19 AM   #1
Default i bought a new dynamite .19 i broke it in now i can't get it started help???
i got my dynimite .19 engine i broke it in as instructed then it got hot out side the next day i tryed to tune it but failed it was spiting fuel out of the pipe on the factory settings and wouldn't start i tryed to lean it off but no luck can someone give me the factory settings or some tips??? thanks
nitrotmaxxw/.19 is offline   Reply With Quote
Old 06-21-2010, 08:44 AM   #2
glowplug...
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 06-21-2010, 08:47 AM   #3
tryed that.
Old 06-21-2010, 09:30 AM   #4
mugenize1's Avatar
Sounds like you very rich if the pipe is spitting fuel. Try this put the bottom needle flush then turn it in 1/4 turn in, put the top needle 2 1/2 turns out from closed you should be able to get it started with this setting hope it helps,
mugenize1 is offline   Reply With Quote
Old 06-21-2010, 09:39 AM   #5
JetMD's Avatar
+1 for it's rich. Also, pull the pipe off and dump out the oil. Might be filled up which won't let the motor run. Good luck.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 06-21-2010, 12:42 PM   #6
just pulled off the pipe and a ton of fuel came out hopeing that was my problem..
Old 06-21-2010, 04:29 PM   #7
still not running anymore ideas??? im think of throwing this thing in the trash
Old 06-30-2010, 05:46 PM   #8
skydark_34's Avatar
check ur throttle opening first,adjust low end needle flush then turn it in 1/4 turn in, adjust the high end 2 1/2 turns out from closed and try again.check ur glow heater an see if it cooks with enough heat.
skydark_34 is offline   Reply With Quote
Ontario 1/8 On Road Racing Club ElliotCanada Nitro On-Road 615 07-23-2008 10:02 AM
