Old 06-09-2010, 09:26 AM   #1
wmay11's Avatar
Default Synthetic oil
Hi guys, do you have any ideas where I can source good synthetic oil for mixing fuel. I am currently using Motul but MSSR, Klotz, Meccamo will do. I am in South Africa so it will have to be shipped international.
Thank you
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 06-09-2010, 09:30 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
Castrol MSSR can be found on the "Castrol Classic" website, it is a special department in the UK. Also M50 (or Racing 50), R30, R40 can be found there.
Other option is the Castrol A747 whis is an half synthetic oil.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-09-2010, 09:41 AM   #3
wmay11's Avatar
Are you running with MSSR? I hear it is good.
Old 06-09-2010, 04:19 PM   #4
Roelof's Avatar
Pure MSSR is not that good. I have runned for many years 7% MSSR and 3% M50 and did not have any bearing failure and rust.
Friends have played with Shell Racing-M which does give an exelent performance but a very dirty combustion (black piston). This stuf is very thin, makes fuel look like water and does need a delicate tuning.
Old 06-11-2010, 03:01 AM   #5
wmay11's Avatar
Where do you get the Shell racing M from?
Old 06-11-2010, 11:26 AM   #6
Roelof's Avatar
Shell racing-M is listed on the Shell website at the motosort department, it is a castor oil for karts and motocross. Probebly you will find it on Ebay.
Old 11-04-2012, 02:22 PM   #7
Lille-bror's Avatar
Any of you have tried Castrol Racing R30?
Castrol Racing R30
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 11-04-2012, 04:10 PM   #8
Roelof's Avatar
I know the R40 is well used in RC plaines. I have read the documents of these oils and it was telling to use a drop of aceton to get it mixed with methanol.
Old 11-04-2012, 04:22 PM   #9
Lille-bror's Avatar
Thanks again Roelof
Found this:
Castrol R30
PRODUCT DESCRIPTION
Might give it a try if my AeroS isn't good enough.
I miss you Amy...
After run oil? srowell3 Nitro On-Road 43 02-22-2007 08:51 PM
Synthetic Oil or Castrol Oil??? TC3 SS Nitro On-Road 26 09-18-2005 11:53 PM
Bearing Oil? trf415 Electric On-Road 20 04-02-2004 05:58 PM
