Old 05-14-2004, 04:33 PM   #1
Default Is it possible...
...to make a fuel bottle that doesn't leak? I've gone through three already.
DAUER962 is offline   Reply With Quote
Old 05-14-2004, 04:49 PM   #2
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Is it possible...
Try Ofna one or HPI one they both are good. and Delta one too
Ah10 is offline   Reply With Quote
Old 05-14-2004, 06:10 PM   #3
Default Re: Re: Is it possible...
I have the HPI one and it leaks.
Old 05-14-2004, 06:15 PM   #4
DOMOisCOOL's Avatar
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Default Re: Re: Re: Is it possible...
Which part?
DOMOisCOOL is offline   Reply With Quote
Old 05-14-2004, 08:20 PM   #5
Right there.
Old 05-14-2004, 09:52 PM   #6
Trader Rating: 2 (75%+)
Never had a problem with the Dynamite or Traxxas pit fuel bottles.
The Delta bottle is also good.
PUNISHER is offline   Reply With Quote
Old 05-14-2004, 09:57 PM   #7
Techart27's Avatar
I've been using a Kwik-Pit 500cc (made by duratrax) and it has no leak problems.
Techart27 is offline   Reply With Quote
Old 05-14-2004, 10:29 PM   #8
corvettecrazy's Avatar
Send a message via AIM to corvettecrazy
I've gone through 4 duratrash bottles, they ALWAYS crack/split around the neck of the bottle.
corvettecrazy is offline   Reply With Quote
Old 05-15-2004, 05:03 AM   #9
VenomWorldOrder's Avatar
guys i'll give you the secret tip to a fuel bottle to never crack;
LEAVE FUEL IN IT!
the bottles crack around the neck (were the rubber seal is) because the rubber dries up.
if you leave a little fuel in it, 100ml or so it will evaporate and keep the rubber moist. leave the rubber cap on so the evaporation stays in the bottle.
if all else fails use a party baloon, or anything similar ( ) to create a tighter seal...... or seal it up with some silicon gasket.
VenomWorldOrder is offline   Reply With Quote
Old 05-15-2004, 06:43 AM   #10
LEAVE FUEL IN IT!
I didn't own any of them long enough to leave fuel in them, they all cracked the first or second time I used them.
Old 05-15-2004, 04:15 PM   #11
Q
Q's Avatar
http://acehardwarehobbies.com/2.2/ca...oducts_id=2862
Q is offline   Reply With Quote
Old 05-16-2004, 11:15 PM   #12
Rapid Roy's Avatar
That's my favorite one too.
Sounds like you're tweaking it too hard when you are removing the top of the bottle. Here's the trick. Never remove the nozzle or top from the bottle. To fill, squeeze the bottle, put the tip down into your quart or gallon bottle and suck the fuel into the filler bottle. No mess or spills. Thats the reason I like the 500ml bottle, its more ridgid and draws the fuel in more easily then the larger bottles.
Rapid Roy is offline   Reply With Quote
Old 05-16-2004, 11:33 PM   #13
InitialD's Avatar
Has anybody used this before?
The bottle is one of the biggest at 800 cc.
Old 05-16-2004, 11:47 PM   #14
Vinyard's Avatar
good stuff.. value for money too
Vinyard is offline   Reply With Quote
