need ofna dm1 1/7 wheel base info please help
i am look for someone that owns a dm1 1/7 to measure the wheel base for me . i am cutting a longer chassis for my gtp2 to make it a 1/7 scale and going to use the dm1 1/7 body. just need to make sure if tower hobby spec are correct sometimes there a little off . i tried to contact ofna and had no luck could only tell me the measurements of the box it come in believe it or not. need someone to measure the wheel base for center axle from front to back . and how wide the track is pic below will help thanks
thank you very much the track is only 3mm smaller then my gtp and the dm1 1/7 center dog bones will fit after i make a longer chassis that is 58mm longer 28mm added to either side of the center diff so it will work perfect
