Old 06-01-2010, 03:40 AM   #1
Default nitro tc3 a none starter/ help??
ok so i have now done everything to my tc3 (bear in mind i am well familer with nitros) BUT man i never seen something like this.
it burbles to start and maybe fires for 4-5seconds and no more then,every thing fine,checked carb,tank,its now getting fuel to carb,just wont fire....
i have needles set.
what would be best needle settings for starters again just in case/??
im stumped.
thanks
dan
dc2 man is offline   Reply With Quote
Old 06-01-2010, 06:58 AM   #2
jakerz's Avatar
you try changing the glow plug? How old is your fuel?
jakerz is offline   Reply With Quote
Old 06-01-2010, 09:34 AM   #3
turns out it is a .15 engine with two speed atached.
strange it has 22 on the other side of it lol .....mmm oh well.
still no starting,i changed the piston/sleeve 3 times for 3 differnt ones and still no success at all.
im giving up on this project a while.
what the hell could be wrong with it..... mmmm
Old 06-01-2010, 11:35 AM   #4
jakerz's Avatar
you put three different piston/sleeves into it? Were they pistons/sleeves from another TC3 engine?
HAve you checked your glow plug? How about your ignighter?
Old 06-01-2010, 02:52 PM   #5
hey jakers thanks mate for the input & sorry if my info is a little shabby up till now.
soooo,ok the engine is a pro 15,NO NAME anywhere that i can see other than on one side under exhaust manifold digits "15" engraved,other opposite side "22" engraved in the lower casing/bottom end.
carb,tank,exhaust all good on inspection,i have built loads of nitros down through the years before racing largescales,now im getting back in to my nitros again.
i have never encountered any problems untill now.
everything seems to be ok,i tried 3 differnt liners and pistons of the same capacity and none will make the beast run.
needle settings.
low: flush with top casing which houses the screw itself
high: 2 turns out from shut.
glow system perfect,new plug & plenty of ignition.
fuel is tornado 25percent,works a treat in my hyper 7
this is addling my mind!!!!!!!!!
thanks folks huge amounts....
dan
Old 06-02-2010, 05:04 AM   #6
fastharryDOTcom's Avatar
needle settings.
dan
try extremes....try turning the low end screw in a half a turn. Then return it and let the high end needle out 3 turns. The engine runs, just won't draw fuel which usually indicates a vacuum problem. Is the piston and sleeve in the correct orientation? Are the needles clogged in the carb?..Is there a hole in the gas tank?...do you have the exhaust tubing running to the tank?..
visit fastharry.com We are always updating the site with new cars and cool rc stuff.
old user name "fastharry"Posts: 2,845 Original join date 2001..HPI Challenge Winner.
fastharryDOTcom is offline   Reply With Quote
