Old 05-09-2004, 04:31 PM   #1
Default pullstarter not pulling?
hello i was just cleaing my engine with after run oil and i pulled the pull stater a couple of time then it just wont pull any more can it be damaged,broke or is it just flooded? i would like to knwo cause i am ordering some parts for my car and woul dlike to order that piece if i need it.
write abck
chris246810 is offline   Reply With Quote
Old 05-09-2004, 05:36 PM   #2
Try loosening up the pull start screws.
maseeh is offline   Reply With Quote
Old 05-09-2004, 06:54 PM   #3
ok heres the deal i just took off the pull start and that works great. not i put it back on the engine and it wasn't puling so i looked where the pull start connects to through the engine and i tried to turn it with my hand and it wont turn so wht can be wrong with the engine what wont let it turn over.
Old 05-09-2004, 07:13 PM   #4
subman's Avatar
pull out your glow plug and pull it, this will relieve the back pressure. Try and let us know what happens.
subman is offline   Reply With Quote
Old 05-09-2004, 07:59 PM   #5
nothing happens it actually feels like the motor is jammed.
Old 05-09-2004, 10:55 PM   #6
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
sounds like you flooded it with AR oil, take the Glow plug out and hold the car upside down hopefully most of the oil will come out, if not that your piston and sleeve may be stuck let us know
Smoke21 is offline   Reply With Quote
Old 05-10-2004, 05:36 AM   #7
i tried turning it upside down and nothing came out. should i go head and check my pistion ?
Old 05-10-2004, 07:14 PM   #8
my piston was stuck on somthing but i got it loose but have to buy a new rcoil starter. thanks for your help . does that usally happend with the piston. and what usally goes bad (breaks) alot on a nitro car? belts,breaks,tires,etc etc.
OS rg-x pullstarter skengines R/C Items: For Sale/Trade 0 06-05-2007 06:53 PM
2.5 Pullstarter t_mac710 R/C Items: Wanted to Buy 0 04-08-2007 01:58 PM
Help! Engine pullstarter broke! fastfad Rookie Zone 4 06-04-2005 04:51 PM
broken pullstarter thinguy10 Rookie Zone 3 02-11-2002 08:00 AM
broken pullstarter thinguy10 Nitro On-Road 8 01-01-2002 08:21 PM
