Old 05-24-2010, 12:09 AM   #1
Default two speed Question
i was wondering what the setting for the two speed clutch is on a mugen mtx4 because it seems that it is hotting to hard when shifting and not as smooth as other cars. should i be running a stock spring because right now iam running the super hard spring and yellow clutch. ans should i be running a lot more play then 5 thousands end play on the clutch. please help me need some help also i run at a large track should i make the car shift early and drag out the second gear??
infernoman2008 is offline   Reply With Quote
Old 05-24-2010, 12:47 AM   #2
Once the clutch is engaged it remains engaged. What it sounds like is the two speed (inside the two gears) has to much of a gap. It should be set to the smallest amount possible. It will allow easier shifting from first to second.
Shawn.
Shawn68z is offline   Reply With Quote
Old 05-24-2010, 01:51 PM   #3
JetMD's Avatar
Here's the file you need to adjust the gap.
http://nitrokb.netne.net/mtx4/pdf/mt...adjustment.pdf
This website has alot of good info on the mtx-4 if you're new to it.
http://nitrokb.netne.net/mtx4/index.html
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
2 speed question on TC3 alucard13 Nitro On-Road 17 05-02-2003 02:07 PM
