Old 05-06-2004, 09:10 PM   #1
Default STS d5 carb tuning question?
Hello My name is Joe I am new to the forum. I found it when I was looking for sts info on the web .I just got a D5 engine and was first looking for some places to buy parts for it , and some base carb setting, this engine is broke in but i messed them up and need to know were to start over. I did a search for this info and cant find the settings. So thank you for any help in advance.
h22ajspec is offline   Reply With Quote
Old 05-06-2004, 09:12 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: STS d5 carb tuning question?
try this forum it is all about STS engines http://www.rctech.net/forum/showthre...648#post864648
Old 05-06-2004, 09:14 PM   #3
Thanx that was fast!
Old 05-06-2004, 09:15 PM   #4
Super Moderator
Marcos.J's Avatar
just trying to help
Old 05-06-2004, 10:18 PM   #5
rc-mushroom.com stocks a lot of parts for STS engines if you need to order some??
GUNPOWDER is offline   Reply With Quote
Old 05-07-2004, 07:39 AM   #6
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
The new D5R might have a better version on carb. But, nonetheless I see those test drivers having problem adjusting it also. The engine seems to run very well when it's really hot.
eddiethefish is offline   Reply With Quote
Old 05-07-2004, 09:18 AM   #7
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
Default Re: Re: STS d5 carb tuning question?
very true on the "hot temperament"
adjust the needles when engine is hot enough,... make it a bit rich when warm, so you'll get the max punch when at "STS working temp"
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
Old 05-07-2004, 09:21 AM   #8
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: STS d5 carb tuning question?
When i ran my STS it ran better at 285 than 265 it seemed that the hotter it got the better!
Old 05-07-2004, 10:33 AM   #9
Default Re: Re: Re: Re: STS d5 carb tuning question?
That was how hot those test drivers ran the engines. If it runs well, keep it that way. Keep us informed of how fast the wear on the conrod and crankshaft pin, will you?
Old 05-07-2004, 10:36 AM   #10
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: Re: Re: STS d5 carb tuning question?
i ran 2 seasons with that motor and at least 5 gallons of 30% fuel , took it apart after 3 gallons to inspect it and that motor it still going, i guess is how you tune it and what fuel you use in it, and of course after run oil every time after use.
Old 05-07-2004, 10:43 AM   #11
Default Re: Re: Re: Re: Re: Re: STS d5 carb tuning question?
How thick is the head shims in total?
Old 05-07-2004, 10:46 AM   #12
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: Re: Re: Re: Re: STS d5 carb tuning question?
using one shim .03 and a cold plug
Tuning with carb restrictors henry Nitro Off-Road 5 06-02-2008 08:26 AM
carb tuning help! plz. Ti-isfly Nitro On-Road 2 09-13-2006 12:45 PM
Carb Tuning question CHEWY078 Onroad Nitro Engine Zone 1 10-30-2005 01:39 AM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
Help tuning Carb, XXXN-T RebelRacer Electric Off-Road 9 08-18-2004 06:33 AM
