Old 07-11-2006, 12:00 PM   #1441
Kurly's Avatar
Default Clutch
Sounds good...........ever have a problem just PM me and Ill give you the help you need........good racing.
L2Kracing, LeisureHours Hobbies & Raceway
Gizmo Racing USA, ARC USA, Motiv RC.
Kurly is offline   Reply With Quote
Old 07-11-2006, 01:06 PM   #1442
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by jjmudd
the mill from his car for the mains......which I won!!! Now, to rebuild my C5 and put my clutch together properly!!!
What... no fast 1/8th's up there that day JJ? hahaha Patience... ill be back up there soon . Should get my JP sleeve back fairly soon. Also from a bit of discussion with some Nitro gurus, i stupidly forgot to shim my engine when i changed from racing 20% to 30% Hence the engine would have been detonating badly (its all black inside ).... just wait till i sort out my engine... and I install the R parts....
Oh and carefull with the whole "i won this and i TQed that".... you sound like someone else i know
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 07-11-2006, 01:08 PM   #1443
axle182's Avatar
Oh and if you need your centax sorted let me know. Ive found out a good way to set them, seems to work great (similar to the old setup for the serpent clutches). Ive had problems with clutches before but ive never had the weights come out even when my clutch bolt came loose!
Aaron "AJ" Freind
Old 07-11-2006, 01:11 PM   #1444
Corse-R's Avatar
Not necesarily is damaged, but the best you can do is to look at the piston and the combustion chamber and see if are pitted, if the answer is yes... too bad. If not, you're a lucky guy. Black residues doesn't mean damage, only a partial combustion and soot formation (almost all times could be cleaned with a wipe and some fresh fuel).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-11-2006, 01:13 PM   #1445
chicky03's Avatar
Send a message via AIM to chicky03
Anyone ever have the clutch fly weights spit themselves out of the clutch?? (I did today!!??) The clutch bell was spaced at no more than .6mm without the rear bearing in and then reassembled. Do you need to shim the rear bearing as well? And if so what are the guidelines for shimming the rear bearing?
John
If your weights are worn they will come out. I had that problem this past weekend and Mike S. told me to check them. They were worn and when I put new ones in I did not have the problem anymore. I would check them against a new set to see.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 07-11-2006, 01:22 PM   #1446
axle182's Avatar
It looks to be burnt on pretty bad (didnt get any high temps that day either) My Piston and sleeve are currently being checked and squeeze if required, and i didnt notice anything pitted when i stripped the engine. Considering how much these P/S sets retail for.... im very lucky. Ill shim it out for sure. Is there anywhere on the net that explains how much to shim? or do people just add 1 shim... or 2? any ideas?
Aaron "AJ" Freind
Old 07-11-2006, 06:41 PM   #1447
Boz
Trader Rating: 23 (100%+)
Axle182, Axle182, Axle182. What are doing? 25% 0.7mm 30% 0.8mm.
Didn't I teach you anything.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 07-11-2006, 08:23 PM   #1448
dpdiehl's Avatar
Has anyone had a chance to test the new parts?
H0139-B front upright (MRX4)
#H0181A 3mm spacer (0.5mm/10 entrance)
#H0181B 3mm spacer (1mm/10 entrance)
#H0181C 3mm spacer (2mm/10 entrance)
#H0181D 3mm spacer (3mm/10 entrance)
dpdiehl is offline   Reply With Quote
Old 07-11-2006, 08:36 PM   #1449
HarKonnenD's Avatar
Send a message via AIM to HarKonnenD
What was the use of the 4.5, 5.5 and 6.5 rear brace thing for the bulkhead again? Anyone know?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 07-11-2006, 08:48 PM   #1450
dpdiehl's Avatar
they raise and lower the rear roll center by raising or lowering the hinge pin height. 4.5 gives the car the lowest rear roll center and is what Mike Swauger uses for his baseline set-up. A lower roll center gives more weight transfer. Higher roll center is closer to CG so there is less weight transfer.........I think...or is it the other way around
Old 07-11-2006, 10:32 PM   #1451
jjmudd's Avatar
Just trying to taunt you into coming back up here man!!! Stop racing your real car and put me in my place!!! LOL Our last race is still the best 10 minute race I've had in long while!!!
jjmudd is offline   Reply With Quote
Old 07-12-2006, 11:25 AM   #1452
HarKonnenD's Avatar
Thank's for the info!
Old 07-12-2006, 11:37 AM   #1453
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
what is this 3mm spacer business? i understand the new upright and have yet to test but will soon, but what is this 3mm spacer with 10 entrance thing? picture?
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 07-12-2006, 11:38 AM   #1454
axle182's Avatar
Boz your a lifesaver, but bloody hard to get in contact with! lol. You and Taber should check your mail!.
Thanks bud. I got a selection of shims last night from the LHS and ill check out sizes soon. And yes you did teach me alot, but i never said i could remember it! lol
Im assuming you got an R now? how do you like it? My 4 is stripped at the moment, waiting on more parts and finally going to install the R parts (been saying that for a while!)
JJ, now go avay or i shall taunt you a second timer you english food trough water, pig dog you... (monty python )
Ill see you in edmonton soon enough matey, just make sure you keep those lap times low, or you would have spent allll that money for nothing lol
Aaron "AJ" Freind
Old 07-13-2006, 08:21 AM   #1455
iwk2much's Avatar
[QUOTE=nigelnuggets]what is this 3mm spacer business? i understand the new upright and have yet to test but will soon, but what is this 3mm spacer with 10 entrance thing? picture?[/QUOTE
The description below from the website should clarify..
Front Upright <H0139-B>
The position of steering arm was lowered by 4mm. Then, it can be adjusted using different type of spacer (H0181A - D).
Wheel offset can be adjusted using H0268 Axle washers.
MRX4-R New Version Spare Parts
P/N Description
H0139-B Front Upright
H0181A 3mm Spacer 0.5mm (10 pcs.)
H0181B 3mm Spacer 1.0mm (10 pcs.)
H0181C 3mm Spacer 2.0mm (10 pcs.)
H0181D 3mm Spacer 3.0mm (10 pcs.)
H0268* Axle Washer (4 pcs.)
H0474 Chassis
*If you use new front upright H0139B, you need the H0268 Axle Washer.
Mike Strack
iwk2much is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
