Old 06-25-2006, 08:34 AM   #1426
quietstorm76's Avatar
Corse R,
I seem to have a problem when I run a 7mm split. I'm running a MRX3 and every time I run a 7mm split the car pushes and the rear steps out on corner exit. Can't figure it out.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 06-25-2006, 09:56 AM   #1427
Corse-R's Avatar
Originally Posted by quietstorm76
Corse R,
The split for a MRX3 was different, it needed 6mm, the 4 and 4-R needs 7 milimeters... did somewhat similar the first time I put the 4-R on the track with a 6mm split. Doh!
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-25-2006, 06:42 PM   #1428
T-BODZ Terry B.'s Avatar
Thumbs up MRX4R / NINJA Sweep 123 Region 9 Championships!
MRX4R / NINJA Combo worked GREAT this weekend
at the ROAR Region 9 Championships 1...2...3!
1 Jeremy Cupps / MRX4R / NINJA
2 Terry Brown / MRX4R / NINJA
3 Chris Metheny / MRX4R / NINJA
4 Lou Laducca / MRX4R / NovaRossi +21
5 Scotty Barrera / XP4 / MaxPower
6 Ron Guston / EVOLVA / Hot Mod +21
7 Ray Smith / MRX3 / R1WC
8 Roman Ruperts / MRX4R / Dulucca NovaRossi
9 Nathan Guidry / MRX4R / MURNAN Mod R1WC
10 Bob Ingersoll / 960 / MEGA
11 Alan Dyches / MRX4 / ?
12 Brandon McNally / 960 / MEGA
Thank You to MUGEN USA!
Terry
Special Thanks to Sponsors: Mugen Seiki USA, Futaba America, Murnan Modified Motors, VP-Powermaster Fuel & Faskolor
T-BODZ Terry B. is offline   Reply With Quote
Old 06-25-2006, 06:55 PM   #1429
Thanks for confirming that for me. I noticed that the car handled better for me with a 5mm split but everyone else ran 7mm so I kept trying it but it never works.
Primary Weapon: ?
Secondary Weapon: ?
Old 06-25-2006, 09:10 PM   #1430
Trader Rating: 13 (93%+)
Default does anyone have a link to an exploded view of mrx4 ??
thanks heaps
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 06-25-2006, 10:00 PM   #1431
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
woohoo! Ninjas pwned!
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-26-2006, 11:15 PM   #1432
Default is the mrx4 underweight >
at my local track we had a iwnternationals on the weekend and my car was underweight by 35 grams!
this was with no fuel in tank and a full set of tyres 76mm rear 70mm front
Old 06-27-2006, 08:39 AM   #1433
New parts coming for mrx4, this was taken off futaba shop web site.
H0139-B front upright (MRX4)
#H0181A 3mm spacer (0.5mm/10 entrance)
#H0181B 3mm spacer (1mm/10 entrance)
#H0181C 3mm spacer (2mm/10 entrance)
#H0181D 3mm spacer (3mm/10 entrance)
It is the new model front upright for MRX4. When the roll doing with 4mm lowering position of the steering wheel arm, it reaches the point where bump in is attached radius of the corner entrance becomes small. The spacer where thickness differs (H0181A~D) you can use and can adjust quality.
In addition, it is possible, the wheel offset ([sukurabu]) by the fact that interval of the axle bearing it makes 1mm narrow to designate the axle shaft to as outside former compared to 1mm it is possible in this range to adjust the quantity. When cutting the steering wheel by the fact that the wheel offset is taken largely, you hold down from the tire outside in the road surface, from the corner entrance to outside you reach the point where it bends well.
#H0075 MRX4-R chassis kit
65520 (substance price \ 62400/including tax prices \ 84000)
MRX4-R upgraded. The modification point is as follows.
Option H0474 chassis of setting (hard type) standard equipment.
New model front upright (H0139-B) standard equipment.
Rich
Rich05 is offline   Reply With Quote
Old 06-28-2006, 11:56 AM   #1434
Corse-R's Avatar
Default Carbon fiber front body mount....
Does anyone use the CF front body mount besides the looks? Really don't know if is hype, but seemed the car went a little more responsive specially on high speed sections holding more the front of the body (noticed more scratches on the front of the chassis).
Cheers,
Corse-R
Old 06-29-2006, 02:05 AM   #1435
Corse, i am using the carbon fibre body mount and i have noticed a small difference in turning, it seems to have more bite in the tight turns.
i also just bought a couple of blitz bodies for my 4R, they have better clearance over the front shock tower and provide more downforce, i will be running the blitz body at the canadian gas nats this weekend.
i will let yas know how i make out.
AKSHUN is offline   Reply With Quote
Old 06-29-2006, 07:50 AM   #1436
New Front Uproght for MRX4 (H0139-B) in stock now.
Discounted price is 588Yen.
http://www.rctech.net/forum/showthread.php?t=119757
Please email us if you are interested.
Fujio is offline   Reply With Quote
Old 07-02-2006, 07:04 PM   #1437
Joe Os's Avatar
Whats the deff? bet. Stock n new one?
Joe Os is offline   Reply With Quote
Old 07-02-2006, 11:56 PM   #1438
jjmudd's Avatar
Anyone ever have the clutch fly weights spit themselves out of the clutch?? (I did today!!??) The clutch bell was spaced at no more than .6mm without the rear bearing in and then reassembled. Do you need to shim the rear bearing as well? And if so what are the guidelines for shimming the rear bearing?
John
jjmudd is offline   Reply With Quote
Old 07-11-2006, 10:19 AM   #1439
Kurly's Avatar
Default clutch
JJ After you have got your spacing without the bearing in it, put the bearing back in and spin the clutch bell on the clutch. You should be able to freely spin the clutch bell without it stopping on the pads. Start to shim off the clutch nut or (engine nut) till you get the bell to spin freely. Then put it all together the way you had it. I know my clutch bell inner bearing is spaced about 2 1/2 to 3mm off the clutch nut threads with the bearing and bell all put together with the .06 spacing in it like yours. Let me know if this makes sense to you.
L2Kracing, LeisureHours Hobbies & Raceway
Gizmo Racing USA, ARC USA, Motiv RC.
Kurly is offline   Reply With Quote
Old 07-11-2006, 11:56 AM   #1440
jjmudd's Avatar
Kurly,
Thanks. It makes total sense!! I don't know what the ---- I was thinking. I didn't shim the rear bearing which caused the the clutch bell to woble and allow the fly weights to pop out!!! Live and learn. lol My buddy was leaving early the day my cluth spat out the fly weights and he let me pull the mill from his car for the mains......which I won!!! Now, to rebuild my C5 and put my clutch together properly!!!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
