Old 06-05-2006, 01:34 PM   #1411
sohlman's Avatar
Trader Rating: 89 (100%+)
Is that Carl? I thought he didn't run r/c anymore...
Steve Sohl
sohlman is offline   Reply With Quote
Old 06-05-2006, 02:56 PM   #1412
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
just waiting for the North East to dry-out....what is with this weather??? Steve, looking to either race this Sunday or break-in the Ninja 21...call me
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is online now   Reply With Quote
Old 06-05-2006, 08:13 PM   #1413
jjmudd's Avatar
Originally Posted by Carl Giordano
A few questions to better answer your question...I assume the engine is properly tuned? and not breaking in the motor...if the engine is not spinning at the proper RPM the 2-shoe 2nd speed will not engage. If OK, try this...
1.) Use silver or white paint to color the spring loaded screw head for one of the 2-speed clutch screws. (this will ensure you are making equal adjustments to each 2-speed screw)
2.) tighten the screws until they just fully collapse. Then turn each one out 2.5 turns...this will ensure the car is in first gear and difficult to get into 2nd.
3.) Set the spacing between the 2-speed clutch shoes and the 2nd gear bell by 0.5MM, using the center 2-speed clutch shoes set screws. Equal distance for each.
4.) Run the car under race conditions to adjust the engagment of the 2-speed. (Since we set the screws so tight, this will take a number of adjustments)
5.) loosen the two spring loaded clutch screws by 1/8 turn each time (one is now color silver or white for easy identification, even while the engine is idling) until the 2nd speed engages where you want on the track.
In the begining, be careful not to overrev the engine on a straight, since the 2-speed will be engaged in 1st gear. When you hear / see it not shift on the track, throttle back, bring it in and adjust the spring loaded screws.
I think I have it sorted out. Rookie error!! I feel like a dork. I had the shoes on backwards...long part of the top shoe on the right instead of the right and opposite for the bottom shoe...oooppps. I also sanded the back side of the shoe, because that was what was rubbing on the inner part of the bell housing. I didn't start the car to try out the new set-up but I am pretty sure that was the problem.
Thanks for your tips and sugestions though. I really appreciate it.
John Hughes
jjmudd is offline   Reply With Quote
Old 06-06-2006, 12:04 AM   #1414
jjmudd's Avatar
Here is my final "new to Mugen and 1/8 racing" question. Where can I find a gear ratio chart for the MRX-4?
Thanks,
John
Old 06-06-2006, 03:18 AM   #1415
X4
X4's Avatar
Thanks,
John
www.mugenseiki.com
X4 is offline   Reply With Quote
Old 06-06-2006, 07:28 AM   #1416
Thanks,
John
Really no need to worry to much about gearing, not as critical as electric racing...just do what we all do in NY...biggest clutch bell gears...smallest spur gears and lean the crap out of the engine....
Just kidding of course....or maybe not
Old 06-06-2006, 09:39 PM   #1417
jjmudd's Avatar
NY sounds like my kind of race town!!!
Thanks for all your help guys. I was looking on the U.S. Mugen site and didn't find anything so thanks X4 for pointing me in the right direction.
John Hughes
Old 06-07-2006, 08:54 AM   #1418
jjmudd, i wouldnt recommend playing around with the gear ratio's at this time, use the stock set-up(17,20-46,49) this will provide you with plenty of get up and go till you get some more experience with the car.there should be a final drive ratio chart that came with the kit.
steve.
also, check your side belt(front pulley) you should have the 26t pulley on there, not the 25t.
AKSHUN is offline   Reply With Quote
Old 06-07-2006, 03:53 PM   #1419
jjmudd's Avatar
AKSHUN,
Thanks for the advice. I checked the pully and indeed did have the 26 on. Does anyone klnow of a shop that has the kuwahra aluminum pully set for this car?
Thanks,
John
Old 06-07-2006, 06:18 PM   #1420
Trader Rating: 13 (93%+)
what is the benefit of using aluminium pulleys ?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 06-07-2006, 07:41 PM   #1421
jjmudd, the pulleys look awesome, and are made with great quality, save your money and buy other spare parts, or you will learn the hard way, like i did. the front(24 tooth one breaks belts) the rear (18tooth) side belt one is good , i havent had a problem with that one.However, i am racing alot on high traction race tracks, if your just planning on bashin, then go ahead.
Old 06-07-2006, 08:42 PM   #1422
jjmudd's Avatar
Bought a second car for parts and $400.00 in extra bearings/gears/belts. I just thought that the aluminum pullies wouldn't wear out as quickly.
Old 06-25-2006, 01:25 AM   #1423
Default off power understeer..
hey guys
i had my first run with my mrx4 on the weekend. car handled pretty good in stock setup however i had a problem with off power understeer and on power oversteer.
what i did to help was give less front castor and moved the rear shock up one position.
is the stock droop settings ok for tyres that are 70mm front and 76mm rear ?
i found the stock droop settings to feel like too much ?
im new to this 1/8 machine
thanks for your help
John
Old 06-25-2006, 07:56 AM   #1424
hey bud, try startin with a 74mm rear, using the 7mm split, this is a standard starting point for any set-up.also, check your camber(front) and toe in/out.
hope this helps.
steve
Old 06-25-2006, 08:28 AM   #1425
Corse-R's Avatar
- The diameters stated on the stock setup (69/76mm) probably isn't the fastest combo of tyres, but gives you a good tyre life span. Probably you may want to go smaller for qualifiers (67/74mm is a good diameter without hampering too much the tyre life). Seen people going crazy at 65/72 for qualifiiers, but... they get tyres for free.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
