Old 05-16-2006, 05:08 AM   #1366
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I see more guys using 3 degree of camber in the rear or so and the car just seems a bit more responsive and makes sharper steering rather than 2 degrees. Sure they may wear more or cone, but it all depends on what you like more. I realized using some front droop caused me to oversteer a bit so I'm gonna get rid of that now.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-16-2006, 05:18 AM   #1367
M7H
M7H's Avatar
Setting the downstops to -1 or -2 (or even further), will allow the front inner wheel to have a bit more contact with the surface during cornering......
Serpent
M7H is offline   Reply With Quote
Old 05-16-2006, 12:53 PM   #1368
HarKonnenD's Avatar
Sorry I ment understeer. I may go try 3 degree of camber n see how it works out for that track, or no droop as used before.
Old 05-18-2006, 08:14 AM   #1369
HarKonnenD's Avatar
Lightbulb
Anyone using any aftermarket pinions for the clutch? I've noticed my stock ones seem a lil beat up...yet the spur gears are completely fine?
Old 05-18-2006, 10:42 AM   #1370
Corse-R's Avatar
Yep... excessive wear on the pinions is something usual. Some days ago contacted Dave Cambell (DeltaDave here) and asked about the compatibility of their Hard coated pinions from the Delta XP4 with the Mugen clutchbell, he told me that 1st gear were compatible, but the ones from 2nd gear didn't came with the inner lip that separates from the 1st pinion, so their 1st gear will be compatible with us.
I'm in the process of buying some pinions from Delta and see if they last longer than the stock Mugen aluminium ones. I avoid to use the steel ones.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-18-2006, 12:10 PM   #1371
HarKonnenD's Avatar
Cool. Let me know how that goes.
Old 05-18-2006, 06:11 PM   #1372
choisan's Avatar
I am using a Japanese Brand called Hasimoto, it produces both 1st and 2nd Steels. It lasts almost forever. It is not expensive, i remember the 1st only costed me less than Yen1000. Check it out!
choisan is offline   Reply With Quote
Old 05-18-2006, 08:20 PM   #1373
HarKonnenD's Avatar
Errr..how much is that in US dollars?
Old 05-18-2006, 08:41 PM   #1374
JFCJ's Avatar
Trader Rating: 31 (100%+)
Default currency conversion
1000 JAPANESE YEN (JPY) = 9.0236 US DOLLAR (USD)
www.bloomberg.com
* www.tsrcar.com * John's BSR Racing Tires * Serpent America * BOCA Bearings *
JFCJ is offline   Reply With Quote
Old 05-18-2006, 08:54 PM   #1375
bighurt98's Avatar
Default Where to buy???
Any online store selling the Hasimoto steel pinions for the MRX4R??
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 05-18-2006, 09:36 PM   #1376
choisan's Avatar
check it out from rc champs from japan! They should carry it.
I bought it last time when i was in Japan.
Old 05-19-2006, 03:07 PM   #1377
Default pinions
i noticed my pinions wore rapidly, but then i checked my gear mesh,i had too much play, since i have tightened the difference it has been much better.
still, not too bad considering the power to weight ratio of these cars and the incredible speeds that they reach.
AKSHUN is offline   Reply With Quote
Old 05-19-2006, 03:09 PM   #1378
Default pinions
also, another thing to check is the amount of drag brake that you are running, if any,this can also put alot of unwanted stress on the pinions
Old 05-22-2006, 12:49 AM   #1379
HarKonnenD's Avatar
HMm.. I usually don't run any drag brake at all with my car though.
Old 05-22-2006, 05:56 AM   #1380
Default mrx4
nor do i, Harkonnen. i only mentioned it cause it seemed like he was a beginner and i know that i used to run my brakes a little tight.
i think the pinions will deteriorate after time anyway, nomatter what settings we use, the power of the motors , weight of the car, quick acceleration are all part of the problem.
personally, i find belts wear faster than pinions, i am experimenting with the new kawahara aluminum pulleys, so far, so good.
the true test, however, will be at toledo, next sunday.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
