Old 05-01-2006, 10:57 AM   #1321
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Hmm I may have to try that yellow shoe...and I thought it was the softest type of shoe? Ah well.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-01-2006, 11:18 AM   #1322
sohlman's Avatar
Trader Rating: 89 (100%+)
In my opinion, the red and yellow are very close in grip, but the yellow lasts longer. But remember, the best grip is not always the best setup...too much grip will not give you the snap out of the corners. The engine may even bog if you have too much grip. It all depends on the track conditions.
EXAMPLE: At the LVGP, I got my clutch poppin (thanks Harry) and then the track conditions got a little slick. I had no traction comin off the corners...had to ride the drift. I wadded the car. If I would have had more grip on my clutch (heavier clutch), the engine would have engaged earlier, at less RPMs and I may not have been so loose coming of the corners.
Steve Sohl
sohlman is offline   Reply With Quote
Old 05-01-2006, 11:58 AM   #1323
HarKonnenD's Avatar
I got ya. So far I like the stock grey show. Just need a 16T pinion for more pick up around the track.
Old 05-02-2006, 08:50 AM   #1324
nytaurean's Avatar
Default mrx4-R
I'm having a problem with the tank on my MRX4-R kit i'm building. The tank doesn't line up with the holes on the upper deck. This is really weird. Can someone help?
nytaurean is offline   Reply With Quote
Old 05-02-2006, 09:37 AM   #1325
Please give me a call at Mugen USA. Some of the MRX4-R kits were sent with MRX-3 tanks. Call me and I will get the right tank sent out to you.
Mike_Swauger is offline   Reply With Quote
Old 05-02-2006, 10:16 AM   #1326
Tires on Mugen and Kyosho Wheels
The Tires are in.
Attached a few pictures. At the moment we will have available both Yellow and White wheel. After we run out of Yellow, we will do only White
We have 35, 38 and 40 shore available. Contact your LHS.
Mugen MRX-4-mvc-271f.jpg   Mugen MRX-4-mvc-272f.jpg   Mugen MRX-4-mvc-273f.jpg   Mugen MRX-4-mvc-274f.jpg   Mugen MRX-4-mvc-275f.jpg
Paolo M is offline   Reply With Quote
Old 05-02-2006, 10:48 AM   #1327
HarKonnenD's Avatar
Nice car collection in the back.
Old 05-02-2006, 11:42 AM   #1328
captian's Avatar
why thank you!!!!lol
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 05-02-2006, 01:47 PM   #1329
Marktur's Avatar
Send a message via AIM to Marktur
Default You got my business, Paulo!
I'll be coming to you for tires, my friend.
Thanks,
Mark
Marktur is offline   Reply With Quote
Old 05-03-2006, 02:10 AM   #1330
Do you have the part no. or URL for getting the clutch end play tool for MRX4?
Originally Posted by Lil Paul
Sohlman,
What are the differences with the cluth shoes? Yellow, Red, Grey... If this has been stated before, please reply with link to orignal thread, however i am very interested in finding out whats what.
Also, Kyosho has a tool for the pinion gears on the evolva that works very well for measuring clutch end play. This tool works very well on the Mugen. I dont know if the side of the tool to remove/install gears will work, but the feeler gauge area works nice.
US_MATRIX is offline   Reply With Quote
Old 05-03-2006, 10:52 AM   #1331
Default problems
Can anyone help me with 2 problems with the MRX4 and the engine.
I have a novarossi RX21R1WCS engine.
the engine is one race old. I'm sure I didn't over heat it. It was running
at 190 degree and the plug is still in good shape. but it died twice on the track. It was running rich for the most time, and it would suddenly become
lean and picked up speed. and twice the engine died when that happen.
I took the engine off the car after the race and I can feel not a lot of pinch
anymore. There is still compression, but I can turn the flywheel with my whole hand without too much affort when the plug is screwed in. Is this normal?
2nd problem is with handling... Do you have to use one-way? My car is very unstable under braking. I lock the rear wheel pretty easily even tho I was being very careful with the brake. I was using the stock tires. If I have to use the oneway, how can I add more braking power but not locking it up?
Thanks!!
powerdrifter is offline   Reply With Quote
Old 05-03-2006, 12:15 PM   #1332
M7H
M7H's Avatar
Maybe some dirt came in the engine?, and left some scratches, with the result of loosing compression.... and that might also be the reason of the engine leaning itself.......
Thanks!!
If you don't use the 1-way, it will not help you with breaking, instead you also loose a lot of traction "on power"......
You can "lock" the 1 way, but in general this is only done in rain conditions....
The solution is give your car even less break power, by setting it on your remote, or change the servo-breaking linkage .....
Serpent
M7H is offline   Reply With Quote
Old 05-03-2006, 12:38 PM   #1333
Thanks,
How do you prevent dirt from getting inside the engine. Isn't the fuel
tank has a fuel filter already?
Old 05-03-2006, 01:06 PM   #1334
M7H
M7H's Avatar
I presume you also have an airfilter?....
This might be the problem, if it is damaged.....
I use these ones:
http://www.mytsn.com/products/product.asp?prid=675
with an INS box:
http://www.mytsn.com/products/desc.asp?prid=677
I never use my filters for longer then 3 races + 3 training days.............
Serpent
Old 05-05-2006, 11:08 AM   #1335
HarKonnenD's Avatar
Anyone jumped to the new MRX4 R hubs? I personally been running the MRX4 for quite some time now (practicing skills) and truthfully have never worn the front belt or middle belt. The only belt that got destroyed was the rear belt and spool due to a rock lodging in there. I may just purchase the old hubs and or try the new ones if they are the same price.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
