Old 04-27-2006, 10:08 AM   #1306
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally Posted by Fsturbo15
FYI, you were skipping the last turn, don't know if you where doing it on purpose because of the dirt though.
Maybe we can meet up at the track one of these days.
FYI there are many layouts for the track, but it was a practice run to warmed up the engine not an actual full lap. I didn't realize he was recording till I hit the straight away. Its been weeks since the engine has been ran and although it was in the 50s there was a lot of cold breeze so tuning was a little harder. Later on around 3 it got a lot warmer and the temps held at around 60. I'm going back sunday with everyone else - feel free to stop by. I also hear you are joining 8th onroad. Did you get your gear yet?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-27-2006, 12:40 PM   #1307
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
I've had my car setup for quite a while now.
I know they're many layouts, I was refering to the official layout used during races though.
I doubt sunday, maybe saturday.
Did you run during last years Chester P. Challange or any other events?
Fsturbo15 is offline   Reply With Quote
Old 04-27-2006, 05:01 PM   #1308
HarKonnenD's Avatar
Back then I recall only having the R40 and I didn't run there, but I ran at Floyd Bennet field a few times for practice laps and events. If your car is setup come down to the track when you have time. You are a lot closer than I am anyway. Weather is still good for sunday and I'm definately going.
Old 04-28-2006, 05:47 AM   #1309
Trader Rating: 13 (93%+)
hey guys
i was t hinking of selling my new mrx-4 to buy the new mrx4r
is it worth it ?
dunno if i can be bothered to build another kit haha
what options in the mrx4r are worth the upgrade to the mrx4
the belt tensioners seam pretty important
what do the new shock towers provide ?
thank you
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-28-2006, 06:24 AM   #1310
M7H
M7H's Avatar
Originally Posted by mrgsr
hey guys
is it worth it ?
Sell your MRX4 and upgrade to the S960.......
Serpent
M7H is offline   Reply With Quote
Old 04-28-2006, 09:23 AM   #1311
HarKonnenD's Avatar
These parts here will cost you less than the kit and convert it to the R. I personally run the MRX4 kit stock as do some others I've seen with no complaint about them. The stock grey show works good enough for me and isn't as expensive as the yellow shoe. It also doesn't wear as much. Other guys probably like it, but work on clutch setup first.
H0148 Front Bulkhead
T0154 Eccentric Hub
H0149 Rear Bulkhead
H0566 Front Damper Stay
H0567 Rear Damper Stay
H0568 Rear Damper Case Long
H0147 Rear Long Upper Arm
H0773 Clutch Shoe (Yellow)
PS. For those who don't have a centax adjusting tool it's worth the $$$. NO more trying to tune with a small allen wrench or hacking the nut with a pliars (you know who you are!). Buy one today!
Old 04-28-2006, 10:50 AM   #1312
Team Kamikaze's Avatar
Around $ 200.00 to $ 230.00 To upgrade a MRX 4 to MRX 4 R
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-28-2006, 10:58 AM   #1313
gfd2726's Avatar
Send a message via AIM to gfd2726
Just upgrade to an R when it's time to rebuild the whole car.
gfd2726 is offline   Reply With Quote
Old 04-28-2006, 12:45 PM   #1314
Jason Smith's Avatar
For me , the yellow shoe lasts about 3 times longer than the grey. The yellow shoe also works very well, but it just seems the grey is a little easier to dial in.
Jason Smith is offline   Reply With Quote
Old 04-28-2006, 05:17 PM   #1315
when changing to the eccentric hubs with belt tensioners, do you need to change the bearings that sit on either side of the diff and one way ?
does that clutch adjusting tool also fit on the kyosho clutch nut ?
Old 04-28-2006, 05:23 PM   #1316
Um, I'm not sure about the MRX4R, but the bearing size did change when the Evolva went to the eccentric hubs. So, those bearings are probably slightly smaller in the outside diameter.
Yes, the Mugen clutch nut tool does work with the Kyosho clutch nut as well.
darkangel is offline   Reply With Quote
Old 04-28-2006, 05:41 PM   #1317
gfd2726's Avatar
No, you don't have to change it. They're the same.
Old 05-01-2006, 07:02 AM   #1318
trashcar's Avatar
MUGEN ,everything fits out of the box,responds well to adjustment,excellent baseline setup in the box. You can add whatever hopups you wish,but out of the box it needs nothing.
trashcar is offline   Reply With Quote
Old 05-01-2006, 10:07 AM   #1319
Lil Paul's Avatar
Default Clutch Shoes
Sohlman,
What are the differences with the cluth shoes? Yellow, Red, Grey... If this has been stated before, please reply with link to orignal thread, however i am very interested in finding out whats what.
Also, Kyosho has a tool for the pinion gears on the evolva that works very well for measuring clutch end play. This tool works very well on the Mugen. I dont know if the side of the tool to remove/install gears will work, but the feeler gauge area works nice.
Lil Paul is offline   Reply With Quote
Old 05-01-2006, 10:53 AM   #1320
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Lil Paul
Sohlman,
Lil Paul,
Red shoe: soft shoe, most grip, shortest life span, works well with aluminum clutch bells
Yellow shoe: med-soft shoe, a little less grip than red, medium-short life span, works best a little glazed with steel clutch bells
Gray shoe: med shoe, good grip, medium life span, perfect amount of slip, works best with the steel clutch bells
Black shoe: hard shoe, least amount of grip, longest life span
I've only used that tool for end play...lately, I've been learning how to measure by feel. Takes a lot of practice though. Hope this helps.
Steve Sohl
sohlman is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
