Old 04-21-2006, 06:58 AM   #1291
Trader Rating: 13 (93%+)
Originally Posted by M7H
what about camber... really important to set that right.....
i used the rpm camber gauge to set camber
i find it easier to set the camber at the ride height
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-21-2006, 07:43 AM   #1292
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
The Hudy is only $130. To make a board it only costed me $8 for some melamine board...enough to make two setup boards. The decal is $13. I got the metal one which is why it's that price, but the plastic one is cheaper. The downside to it...it's harder to read especially in sunlight. PMB is good nontheless, but I like the Hudy metal ones. Sure I could've gone with the Hudy tire truer as well, but it's expensive...costing $300. Hudy quality though and the resale value will still be pretty high.
Yes I know the toe in gauge is upside down.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-21-2006, 07:18 PM   #1293
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
OK, I have Ofna 1/10 Starter Box
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXAXU2
and was wondering if I could use it ( or modify it ) as a stater box for my MRX4?
THX in advance
And what's the best charger to use on the 12V battery? Can I use an Integy charger that I use on my electric RC cars?
THX a second time...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-21-2006, 10:44 PM   #1294
HarKonnenD's Avatar
I use that same dual motor box for 10th on/off, and 8th on/off. It says its for 10th only, but that's BS...total BS. Single motor boxes don't provide much more torque, but rather a little more RPM. Torque is what you need to get the motor crankin and thats where the 12v batt comes in. The 7amp version has enough amps to get your motors spinning and crank the engine. For a breakin simply loosen the plug. I usually put some MMO in the engine, remove the plug, and crank it on my box to get it lubed up.
You may want to use the pegs and you will need 3 to have the car seated perfectly to be started.
Old 04-23-2006, 07:14 PM   #1295
Default some pics of my mrx-4
just waiting on the exhaust pressure chamber to arrive some time today...
Old 04-23-2006, 08:13 PM   #1296
Just wondering where is the best place to get 1/8 scale Tires for the Mrx-4. Thanks for any and all replies
no4hitter is offline   Reply With Quote
Old 04-24-2006, 04:12 PM   #1297
kenshu's Avatar
Best price on tires. But beware. They don't email you after the order or call you. They just show up at your house in 4-5 days.
http://www.brucknerhobbies.com/eightscaletires.htm
Ken Schueler
It's better to get the shoe than the boot. SMAC Rules!!!
2012 ROAR Region 8 Stock Buggy Champion!!!
2012 JConcepts Winter Indoor Nationals Stock Buggy Champion!!
2009 ROAR Region 8 Stock Buggy Champion!!
kenshu is offline   Reply With Quote
Old 04-26-2006, 04:52 PM   #1298
Hey guys
This may sound like a dumb question but are the encentric hubs for the mrx4r the pieces that fit in the new bulkhead? I am in the process upgrading my mrx4 and thats the only piece i need.
thanks
bmcallister is offline   Reply With Quote
Old 04-26-2006, 05:01 PM   #1299
Ron C.'s Avatar
Originally Posted by bmcallister
Hey guys
thanks
Hi bmcallister,
Yes the Eccentric Hubs are the ones that fit in new Bulk Heads....
They are where the bearings ride on and makes both the Front/Rear Belts adjustable.
New eccentric hubs : Part #(T0154)
No dumb question here... If you need anything, please feel free to ask.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 04-26-2006, 05:03 PM   #1300
sohlman's Avatar
Trader Rating: 89 (100%+)
Yes. They hold the bearings and can be set in three different adjustments for belt tension preference.
Or what he said.
Steve Sohl
sohlman is offline   Reply With Quote
Old 04-26-2006, 06:41 PM   #1301
HarKonnenD's Avatar
Here I am at Bridgeport doing a practice/warmup run. Unfortunately the track had some pebbles, but the main problem was the excess dirt. I drifted off throttle going through the last turn (not seen clearly) in the vid. The heavy brownish areas were most dust littered and the other spots can't be seen. A fellow racer brought his leaf blower and that helped out a whole lot. I'd post the pictures, but they are in the video so MRX4 fans check it out! A slightly tragic end for me as a screw got loose on the steering linkage so I went at the wall at nearly 60 though crashed at around 45mph. Broke the left steering knuckle and that's it. On my R40 I would've broken a heck lot more. Enough chit chat...watch the vid!
http://media.putfile.com/Warmup-in-Bridgeport
Old 04-26-2006, 07:24 PM   #1302
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
FYI, you were skipping the last turn, don't know if you where doing it on purpose because of the dirt though.
Maybe we can meet up at the track one of these days.
Fsturbo15 is offline   Reply With Quote
Old 04-27-2006, 07:48 AM   #1303
I have a JP-R01 mod motor with turbo plug.. What is a good fuel to run in it as I am getting back into nitro acing?
THX in advance...
RC Tech member #11
Old 04-27-2006, 07:53 AM   #1304
sohlman's Avatar
Mugen Seiki 20% or 30% will work great.
Steve Sohl
Old 04-27-2006, 08:00 AM   #1305
LOL, that narrows it down....
I used to run 30% in my old 4-tec... Got the motor temp up to 425 the last time I ran it... And that was the last time I ran it....
RC Tech member #11
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
