Old 04-15-2006, 12:13 PM   #1246
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
Originally Posted by Ron C.
Hi Fsturbo15,
The MRX4-R Kits were patterned off the cars that Team Mugen Used at the 2005 Worlds... At that event, they mostly used bodies that are low in the front end for more frontal downforce. And with the MRX3 arms (being "not arched") allowed for more clearance between the Front Upper Arms and the body.
But will this effect the cars performance for people not using low front end bodies?
Fsturbo15 is offline   Reply With Quote
Old 04-15-2006, 12:18 PM   #1247
racer x 1's Avatar
Trader Rating: 27 (100%+)
the swag says that using the mrx3 arms does not affect the way the car handles.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 04-15-2006, 12:35 PM   #1248
Ron C.'s Avatar
Performance would stay the same.
They were mainly for clearance purposes.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 04-16-2006, 07:32 AM   #1249
Ron C.'s Avatar
Hi Fsturbo15,
On a related side note : The arms that come with the MRX4-R Kits are new Front Upper arms (not of the MRX3).
When comparing one from the other, the MRX3 arms are wider (assuming you're looking at the car from it's side).
With the MRX4 (arched) or MRX4-R (not arched) arms, it allows the car to have more available caster settings.
Old 04-16-2006, 07:55 AM   #1250
cdelong's Avatar
Ron,
I thought the MRX-4 and 4R upper a-arms were narrower because the 4 series has an adjustable wheelbase, although I see that you could possibly use the extra clearance to drastically alter caster angles.
Do you ever have occasion to place the top 3mm wheelbase shim different from the 3mm lower wheelbase shim (one forward and one backward)?
BTW- I like the new yellow shoe. How much clutch nut are you running in combination with 3 chamber pipes and the yellow shoe?
Thanks,
Corey
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 04-16-2006, 10:15 AM   #1251
Trader Rating: 13 (93%+)
Default cluth adjust nut..
how far do you guys have your clutch adjust nut screwed in ?
is the books setup any good/bad ?
i saw a guy at the track yesterday and on his evolva he had the nut screwed pretty much the whole way in .. weird ?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-16-2006, 10:42 AM   #1252
cdelong's Avatar
I think 1.0mm is a good starting point.
It all depends on the track, clutch, engine, pipe and your driving style.
KYOSHO EVOLVA
35PLUS21
Old 04-16-2006, 08:47 PM   #1253
kenshu's Avatar
I have my MRX4-R done and I'm ready for Cinn this weekend. It's been 16 years since I drove 1/8 on-road. Should be a blast.
Ken Schueler
It's better to get the shoe than the boot. SMAC Rules!!!
2012 ROAR Region 8 Stock Buggy Champion!!!
2012 JConcepts Winter Indoor Nationals Stock Buggy Champion!!
2009 ROAR Region 8 Stock Buggy Champion!!
kenshu is offline   Reply With Quote
Old 04-17-2006, 04:10 AM   #1254
is thier a 1 piece engine mount for the mrx4 ??
Old 04-17-2006, 05:01 AM   #1255
Trader Rating: 74 (100%+)
Yes, part # H0772 single piece motor mount.
Nitro-mech is offline   Reply With Quote
Old 04-17-2006, 07:15 AM   #1256
Ron C.'s Avatar
Originally Posted by cdelong
Ron,
Hi Corey,
It's correct, the MRX-4 and 4R upper a-arms are narrower (than of the MRX3) because of both reasons you cited.
I just mentioned it on the last post because we had some guys asking if the Front Upper arms in the MRX-4R kits are of the MRX3. They are actually new Arms.
Old 04-17-2006, 07:23 AM   #1257
Ron C.'s Avatar
Ron,
Thanks,
Corey
Measuring it with a caliper from the tip of the crank to the flat part of the clutch nut, I start off at 9.2 and work my way in from there.
As Corey mentioned, "It all depends on the track, clutch, engine, pipe and your driving style."
Old 04-17-2006, 07:27 AM   #1258
Ron C.'s Avatar
Hi mrgsr,
That is weird because he is not allowing the clutch spring to function properly.
Old 04-17-2006, 09:24 AM   #1259
cdelong's Avatar
Ron,
Your quick and informational replies are greatly appreciated from the "little guys" like myself.
How long before 4R spares (A-arms) are readily available? My retailer is not getting his orders regularly filled with 4R stuff and I can't get A-arms. I need 4R front and rear lowers (not old "4" lowers) and 4R front uppers.
KYOSHO EVOLVA
35PLUS21
Old 04-17-2006, 10:04 AM   #1260
Ron,
Hello cdelong,
The MRX-4R lower arms have been in stock for about 4 months. It is a running change so it is the same part number. We have the new MRX-4R upper arms in stock now. Like the lower arms they are a running change so they will be the same part number. What hobby shop do you deal with? We have had these arms in stock for a while so they should be easy to get.
Mike_Swauger is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
