Old 04-05-2006, 10:50 AM   #1201
Roger's Avatar
Those are sweeet Jeremy
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 04-05-2006, 02:16 PM   #1202
Lil Paul's Avatar
Default Thanks
Hey Ron C, thanks for the reply...I never thought about it from that angle. I am going to give it a try, with these new motors making unbelievable power fuel management is definitely a problem.
Lil Paul is offline   Reply With Quote
Old 04-05-2006, 02:18 PM   #1203
Lil Paul's Avatar
Default OOPS
sorry, that last reply was for darkangel, however ron I am sure you will be passing along some good info in the future, so thats a thanks in advance.
Old 04-05-2006, 05:34 PM   #1204
Trader Rating: 13 (93%+)
Originally Posted by cdelong
The lower pivot balls determine your front track width so that will vary from person to person. 3mm will get you in the park (around 253mm width).
Thanks for that, im just used to building kits that give you a ball park figure like the kyoshos rrr hehe
what would the gap be for the back ?
sorry about these questions
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-05-2006, 05:42 PM   #1205
cdelong's Avatar
rear pivot balls will be around:
rear ball ~ 3.80mm
front ball ~ 3.20mm
This results in a track width of ~ 264mm and toe-in of about 2 degrees. Obviously the camber is set with the upper arm.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 04-06-2006, 12:05 AM   #1206
juss postin
Mugen_MRX is offline   Reply With Quote
Old 04-06-2006, 06:40 AM   #1207
Default Roll bar
What do you guys think about the rear adjustable bar?
Does it work?
Or is it better to stick with the original 3mm fix ?
THks in advance
Luís Cortez
Luís Cortez is offline   Reply With Quote
Old 04-06-2006, 01:26 PM   #1208
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Default roll bar
Most pro's I've seen use the wire bar, not the adjustable one.
ralph m is offline   Reply With Quote
Old 04-06-2006, 01:52 PM   #1209
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
hey Ralph, have you seen the new photos of the 201 Race facility in Brandywine Maryland...looks as if its the largest on-road facility in the country and within a 4 hour drive....I may be making the trip down this weekend...depends of the rain stays away...check out the photos on the racing forum thread of RC tech
Ron: nice paint job.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 04-06-2006, 02:18 PM   #1210
Lil Paul's Avatar
Default 301 PICS
Carl, where are the pics of that new track in MD? I want to go down next weekend to practice if I can. Good Friday makes it a long weekend for me.
Old 04-06-2006, 03:06 PM   #1211
http://www.rctech.net/forum/showthre...&page=34&pp=30
Old 04-06-2006, 05:16 PM   #1212
Default front stablilizer bar ..
hey guys i seam to have a build problem with the front stablizer bar.
ive built the front end as the book, set the lower arm height from the ground to zero like it says in the setup sheet..
however the stablizer bar is pointing up at angle. now this doe snot seam right as my rrr lays flat and so did my previous cars.
ive pushed the stablizer bars in as far as they go but they still seam long.
have i done something wrong ?
haha
Old 04-07-2006, 04:45 AM   #1213
Default front pivot balls and front sway bar
hey
i set the pivot balls with a 3mm gap measured from the bottom and i noticed that the universals dont have enough inward travel ?? meaning the suspension arms dont have enough upward travel. i noticed this when i unscrewed the pivot balls i was able to lift the suspension arms much higher.
what are you guys setting the front track width to be ?
ill sort this out when i put the wheels on.
please see my pics. this pic is with the arm height set to zero as per the setup sheet.
does any one have any front on pics to see how the sway bar should look ?
Thanks heaps! John
Old 04-07-2006, 07:16 AM   #1214
chicky03's Avatar
Send a message via AIM to chicky03
I am not sure if you made the same mistake I did, but I did not realize at first that the steering blocks have a right and left. I had them switched at first and the suspension had no travel either. Dumb on my part but once I put them on the correct side it was perfect.
Paul
Originally Posted by mrgsr
hey
Thanks heaps! John
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 04-07-2006, 07:19 AM   #1215
what part are u referring to as the steering block ?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
