Old 03-29-2006, 03:16 PM   #1171
Trader Rating: 13 (93%+)
Originally Posted by jeffreylin
No he is talking about the brake disc holder. Both the RRR and the FW05R came with stock plastic ones.
Yeh thats right .. thanks for that guys!
i only asked because i saw a kawahara option and thought the mrx4 wwould be plastic to.
im not a fan of bling options just parts to make the car durable and lighter
are the tyres in the us mrx4 kit 37s as well ?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-29-2006, 04:48 PM   #1172
jeffreylin's Avatar
R/C Tech Charter Subscriber
They were 35's.
jeffreylin is offline   Reply With Quote
Old 03-30-2006, 07:31 PM   #1173
Joe Os's Avatar
Originally Posted by cdelong
Does anyone know.... for sure.... what shore tires come in the 4R kit?
I don't have a durometer, but they "feel" like 35's.
35s think so lol
Joe Os is offline   Reply With Quote
Old 03-30-2006, 07:41 PM   #1174
cdelong's Avatar
so that's....
one 37s
one 35s
and a few laughs
anyone know for sure.... Is Ron C. in the house??
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 03-30-2006, 09:39 PM   #1175
damn how would 35s last on such a high powered car ?
Old 03-31-2006, 03:14 AM   #1176
ruicortez's Avatar
Default Rubber Belts
Anyone tryed the new rubber belts?
I heard that they are good for qualifying but they don't last long.
Is it true?
Best regards
ruicortez is offline   Reply With Quote
Old 03-31-2006, 10:29 AM   #1177
Lil Paul's Avatar
Default Rear Lower Arm Setting
A lil' help would be greatly appreciated. What effect does changing the rear lower arm position have on handling? More understeering, oversteer, side traction, etc. 4.5, 5.5 6.5
Lil Paul is offline   Reply With Quote
Old 03-31-2006, 12:09 PM   #1178
Ron C.'s Avatar
Hi Lil Paul,
Here is basically when I would use the three different rear blocks.
Low Bite traction = 6.5
Medium traction = 5.5
High Bite traction = 4.5
Short Note : The droop setting would need to be re-set as you change from one block to the other since it either raises/lowers your hinge pin position (depending on the block you have on).
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 03-31-2006, 12:22 PM   #1179
Ron C.'s Avatar
Is it true?
Best regards
Hi ruicortez,
We've had a new set of rubber belts hold up through a couple of days of qualifying plus a 45 minute main with no problem. On top of which, they stayed on the car for future practice runs after that.
I'd say the New Mugen Rubber Belts hold up as long as the Mugen Standard Belts (under normal usage). The advantage you get from the new rubber belts would be a more free and smoother drive train.
Old 03-31-2006, 12:30 PM   #1180
Ron C.'s Avatar
so that's....
one 37s
one 35s
and a few laughs
Hi Corey, how are you?
Yes, they would be 35s.
I see you may have upgraded your car to the "R".?.
I hope all is well and will see you at the races....
Old 04-01-2006, 07:55 PM   #1181
Default tyre truing angle for the rear tyres question
hey guys, new to 1:8 question
when truing the rear tyres, how do you do it ? haha
i know with a tire truer but are you meant to cut the rear tyres at an angle like the wheels show on the mrx4 site ?
my tyre truer allows cutting the tyres at angles, is this what your meant to do ?
ive only ever trued tyres for my 1/10
thanks!
John
Old 04-01-2006, 08:42 PM   #1182
jeffreylin's Avatar
thanks!
John
I cut it at 1 degree.
Old 04-01-2006, 11:50 PM   #1183
is that front and rear ?
or just rears
Old 04-02-2006, 01:37 AM   #1184
jeffreylin's Avatar
or just rears
Only rear for me. I cut the front ones 0 degree.
Old 04-02-2006, 09:44 AM   #1185
cdelong's Avatar
I cut mine a little more closer to where the camber is. The more camber you run on the car, the less tire that will be in contact with the pavement if you cut NO camber into the tires. In the rear where you typically have around 3 degrees of camber, if you do not cut any camber into the tires, then only about 1/3 of the rear tire will be in contact with the ground.
In the rear I run about 3- 3.5 degrees of camber, so I cut the tires close to that- maybe a tad less. I run the fronts around 1-1.5 degrees of camber so I just cut them at 1 degree.
KYOSHO EVOLVA
35PLUS21
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
