Old 02-18-2006, 09:58 PM   #1006
clmbia45's Avatar
Smile
Originally Posted by Cat Skinner
"Awesome! Any other upgrades? Anyone prefere the 4.5mm rear lower arm overall or anyone run the stock 5.5mm or even 6.5mm. I changed to 4.5mm, but what sort of effect do they do?"
HarKonnenD,
This is my understanding of the different blocks, the geometery of the 4.5mm provides a lower roll center --- this is good when the track has a higher bite and traction is up. The 6.5mm raises the roll center giving more side bite to the rear wheels --- better as traction goes down and the rear of the car becomes too loose. Loose is fast if you have the throttle finger to control it, some of the fast guys that I race with run the 4.5mm when I'm running the 5.5mm.The trade off is that I get an easier to control car and they get one that rotates throught the corner better.
The other options that also effect roll center are the rear upper arms (mugen) and the front upper arms (Kawahara).
As far as other upgrades there is are a lot of new options;
from http://www.mugenracing.com/
At the Vegas race last week most went from 5.5mm to 6.5mm to find a little more on power traction going through the left sweeper.
Good luck.
WHAT HOLES DO YOU USE WITH THE NEW SHOCK TOWERS?
clmbia45 is offline   Reply With Quote
Old 02-19-2006, 05:29 AM   #1007
jeffreylin's Avatar
R/C Tech Charter Subscriber
Use the same ones as the one you'd use on the old shock tower, that should provide the same geometry.
jeffreylin is offline   Reply With Quote
Old 02-19-2006, 09:52 AM   #1008
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default wow
M.S. you didnt save me any of that track
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 02-19-2006, 10:49 AM   #1009
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Then what is the purpose of the new shock towers if they don't change the suspension geometry? Did you notice a difference on your car?
Racing4Evo is offline   Reply With Quote
Old 02-19-2006, 11:46 AM   #1010
jeffreylin's Avatar
They provide the same angle but allows longer shock body and more shock oil inside. It makes the rear more stable. The front ones went the other way, it shortens the shocks overall.
I think the car has a tendency to come around. The upgrades including the new rear upper arms made it more neutral through the turn.
Old 02-19-2006, 01:22 PM   #1011
Racing4Evo's Avatar
What's the difference between the stock chassis and optional chassis?
Old 02-19-2006, 02:04 PM   #1012
jeffreylin's Avatar
There are some cut outs underneath the engine in the stock chassis but not in the optional chassis, which makes the optional chassis more rigid.
Old 02-19-2006, 07:57 PM   #1013
Chris West's Avatar
Send a message via MSN to Chris West
Only get the option chassis if youve got a low grip track with many tight corners
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 02-20-2006, 10:08 PM   #1014
clmbia45's Avatar
Originally Posted by Ron C.
Hi nils,
Yes, you are correct about when to use the "big blocks" and the "small blocks".
"Big Blocks" when you have the rear set wide
"Small Blocks" when you have the rear set narrow
Hi Ron,
What do you mean when you refer to the "wide" and "narrow" settings?
It would appear that if you kept constant the stock 263 mm track width, using the "big blocks" compared to the "small blocks" would reduce the camber change under side load and make the rear end looser; and vice versa.
What do you think?
Thanks, jack
Old 02-20-2006, 11:04 PM   #1015
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Got my MRX4R's.... Very pumped up to test the boards out on our track.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-25-2006, 04:45 PM   #1016
How many Teeth does the Rear Axle Pulley have on a MRX 4?
ElliotCanada is offline   Reply With Quote
Old 02-25-2006, 10:54 PM   #1017
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Welp guys time to get those Mugens ready. We have to represent and kick some serious booty on the track. My track starts races in april so march I'm gonna start practice,practice, until its perfect. Let's get it on!
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-04-2006, 11:34 PM   #1018
HarKonnenD's Avatar
Officially going to race 8th onroad now. I'm just going to purchase the new bulkheads, spare pinions, spurs, etc. Anyone recommend stepping down to the 16T pinion for first gear. Would I have to change anything else as well...spur wise?
Old 03-06-2006, 09:59 AM   #1019
asw7576's Avatar
What is the different between R and not R ? My LHS only has regular MRX4.
I'm getting confuse choosing MRX4 or MBX5 .
Old 03-06-2006, 10:00 AM   #1020
Default Phillip Abed does it again!
TQ & Win at the Florida State Series race at Kissimmee RC this weekend. Heavy competition but Phillip with MRX4R, Enneti tires and NR power came out on top!
1-8th Open A Main Round# 5,
Race# 11
________________________Driver___Car#____Laps____R aceTime____Fast
Lap___Behind_
Philip Abed #6 103 30:02.239
16.368
Chuck Moon #8 101 30:14.857
16.911
Ashton Brinson #3 101 30:17.622
17.114 2.765
Paolo Morganti #4 98 30:01.254
16.215
Randy Colvin #10 95 30:05.458
17.353
Jim Sowa #9 95 30:17.066
17.731 11.608
Joaquin DeSoto #1 87 30:00.684
16.639
D.J. Apalaro #2 67 21:31.593
16.770
Ben Griffin #5 43 15:17.057
17.658
Scotty Gray #7 10 2:47.830
16.701
jdesoto is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
