Old 12-14-2005, 02:52 PM   #901
nils's Avatar
hello,i have the new front bulkhead can i use it with the kit front damper stay,ore do i use it only with the new front damper stay.
for what type of track do u use the new rear and front damper stay.
nils is offline   Reply With Quote
Old 12-14-2005, 03:23 PM   #902
Ron C.'s Avatar
Nils,
Yes, your may use either the Original Stock Front Damper Stay and/or the New Optional one with the New Front Bulk Heads.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 12-17-2005, 02:06 PM   #903
nils's Avatar
can some wone give me more explanation about the new parts,like the new front and rear bulkheads, and the front and rear damperstay,and the longer rear dampers.
please explain to me what the new parts wil do for the car.
cya.
Old 12-17-2005, 02:17 PM   #904
ogreasurada's Avatar
cya.
The new bulkheads are intergrated with eccenters so you can adjust belt tension. The new front damper tower is designed with lower damper mounting postions (lower angle). The new rear damper tower is to be used with the new longer rear dampers (has higher angle). And I think the longer rear damper is to give the rear more responsive and smoother suspension actions. Hope this helps.
ogreasurada is offline   Reply With Quote
Old 12-18-2005, 08:31 AM   #905
Well guys, I am back into 1/8. Just got a used mrx4 in great condition. Will have to do some reading to catch up with everybody. Christmas came early. Wife wants me to put it under the tree, but I am taking it out today for a test ride then she can wrap it up after I clean it.
CHUCKMANDO is offline   Reply With Quote
Old 12-23-2005, 11:33 AM   #906
Default servo
Hello, I just picked up my first 1/8th scale car. I am not new to RC, and I am a pretty good TC racer. What servo would you reccomend to use and the specs of it would be nice aswell (either KO, Futaba or Airtronics only please).
Happy Holidays
Limbo75 is offline   Reply With Quote
Old 12-23-2005, 11:56 AM   #907
Ron C.'s Avatar
Default Airtronics 94360Z
Happy Holidays
Hi Limbo75,
I use the Airtronics 94360Z on both the steering and throttle.
Been using it for quite sometime now with no problems and therefore recommend it highly.
Here are the Specs:
Weight : 2.12 oz.
Dimensions : 1.54 x 0.79 x 1.47
[email protected] : 4.8 / 6.0
Torque : 100 / 125
Speed : 0.09 / 0.07
Hope this helps.
Old 12-23-2005, 01:56 PM   #908
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I bought a JR digital servo for steering. It has .06 transit time and 128oz of torque. I have a standard throttle servo, but the S3003 works great. Many people at my track use std servos for throttle and do great with them.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 12-23-2005, 03:04 PM   #909
Alright, thanks for the quick responses Ron C. and HarKonnenD.
Old 12-24-2005, 04:17 AM   #910
HarKonnenD's Avatar
NO prob. Before I thought of getting away with a Hi 625mG or this JR 650 that has 138oz torque @ .17transit. Nooo way. Now that I have the new JR servo in, OMG it's so fast n torque. I can't wait to drive it!
Old 12-26-2005, 01:58 PM   #911
ziggy12345's Avatar
Whats the best Futaba digital servo for this car?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 12-26-2005, 02:41 PM   #912
nils's Avatar
he ziggy,you should try the S9451 dig. ihave them for steering and throttle,i have them for more than a year ,have had a lot of crashes,and they are still working fine.
look at mushroom they are between 90$ and 100$.
Old 12-31-2005, 08:37 AM   #913
Default Damper lenght
Hi there!
I was just wondering if someone could advice on how to set the lenght of the dampers via the lower ball stud...
The manual gives no measurements. I built them to 68,5mm right now because when I screwed the ball stud stud all the way up and get it real firm against the damper shaft my front droop was limited to +2.
And a second question: The sweatspot for front and rear downstops seem to be a 0 front and 9 back. Is this setting ok for running the tires down to the rim or would I need to readjust when I set the car back to the original ride height after the tires wore down some mm?
fulcrum2 is offline   Reply With Quote
Old 01-01-2006, 01:35 AM   #914
Ron C.'s Avatar
Hi guys, when you get a chance, go and check out new updates in:
http://www.mugenseiki.com
Old 01-01-2006, 10:35 AM   #915
Default Head gap
Hi there!
Could someone please advice on the head gap for a REX 221p long stroke engine?
The engine came with two aluminium shims each 0,3mm and one copper shim which is 0,1mm.
The native haed gap without any shims measures in at 0,1mm. So in total the head gap set by Novarossi is 0,8mm.
I will race 25% nitro and my two tracks are between 250m and 300m (800-1000 feet) above mean sea level.
Any thoughts?
Many thanks in advance!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
