Old 11-25-2005, 07:07 PM   #856
Yes. I use them both. Do you have the same problem like i do?
manokgt4 is offline   Reply With Quote
Old 11-25-2005, 09:52 PM   #857
nsupra's Avatar
No I dont have the conversion done. What are the benefits of it?
nsupra is offline   Reply With Quote
Old 11-25-2005, 09:53 PM   #858
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Lightbulb
Anyone know a good setup board to use with nitro sedan and 8th onroad that won't break the wallet? I'm still in the market for a new radio, spektrum module, and maybe a vantage pipe for my R40.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 11-26-2005, 12:01 AM   #859
I've seen quite a few racers that uses melamine boards or plexiglass. So i guess you purchase it at your nearest home depot or lowes. Cost you probably less than $10.00. Then, you can buy the plastic set-up board decal separately.
Old 11-26-2005, 12:10 AM   #860
[QUOTE=nsupra]No I dont have the conversion done. What are the benefits of it?[/QUOTE
Bought mine used.. and it came with it already. Well, since your using the rear belts on your front oneway.. it suppose to last you longer.. Since i bought it 5 months ago.. i only replaced it twice over 3 club races and 3 major races. I replaced it not because it stripped but the teeth of the belts where worn out. The only thing that sucks though is i have to shave off a bit of plastic on my right front bulkhead coz it rubs.
But still, i can't figure out why so much play..
Old 11-26-2005, 08:53 AM   #861
HarKonnenD's Avatar
How much for the plastic set-up board decal set now? How do I put those on? If this involves some sort of accuracy, I'd rather just purchase a setup board that make my own.
Old 11-27-2005, 03:11 AM   #862
can anyone tell me if the rear diffs work for the front? I wanna run a diff rather then the one way.
rhed is offline   Reply With Quote
Old 11-27-2005, 09:18 AM   #863
HarKonnenD's Avatar
Lightbulb
Do you see the size of the solid rear axle? No way that huge thing would fit in the front of the car.
Old 11-27-2005, 10:59 AM   #864
nsupra's Avatar
You can get something called a locked front diff. Check out www.gasrccar.com
you can find out more about it there.
Old 11-27-2005, 10:14 PM   #865
I'm sorry forgot to say that I didn't even build my kit yet. So that's means I couldn't tell.. know the funny thing is I got this kit like 3 months ago. And haven't had a chance to put it together. But when my MTX 4 came 2 weeks ago I built it right away..hehehe.. Anyway I put a locked diff for my MTX 4 instead.. Think I'll do the same with my MRX...
Old 11-27-2005, 10:19 PM   #866
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally Posted by rhed
I'm sorry forgot to say that I didn't even build my kit yet. So that's means I can't tell..
Just curious - what makes you want to try this?
JAG Racing is offline   Reply With Quote
Old 11-27-2005, 10:21 PM   #867
Thank you...
Old 11-27-2005, 10:32 PM   #868
ElectricConvert's Avatar
Hi US racers.
Just a question from the land down under, what would a solid front do to the car? Wouldn't that make it push and scrub speed when cornering?
I've been eyeing that solid front from gasrccar but not sure if if its worth getting.
ElectricConvert is offline   Reply With Quote
Old 11-28-2005, 01:22 AM   #869
M7H
M7H's Avatar
In my opinion this is what happens with a solid front:
- it would give friction between the front and the rear tires, this will result in loss of speed....
- If you want to use a solid front, your front and rear tires should be of a diameter that there is no overdrive.
- cornering, especialy with the allready solid rear, would be more difficult.
- more wear on the belt and pulley's, also bigger change of breaking them....
No, in my opinion, a front solid is only usefull in the rain.....
Serpent
M7H is offline   Reply With Quote
Old 11-28-2005, 08:47 AM   #870
asw7576's Avatar
Do you refer to Spool ( Solid front axle ) ??
Spool is good for technical track ( lots of braking before tight turns ) with poor to medium bite asphalt. It's new trend in electric cars now.
Are you sure MRX4 have Spool option ?
The risk : see M7H above
The benefit : you can enter tight corner very fast, brake, and exit like hell.
I think No too because 1). 1/8 cars usually have wide sweeping corners. 2). The middle and front belts might tear apart.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
