Old 11-21-2005, 04:51 PM   #841
Ron C.'s Avatar
Originally Posted by ralph m
Any ideas what the new shock towers will do for the MRX4? They're on the Mugen Japan site under new products.
Aside from giving you more rear damper positions, the new Rear Damper Stays work hand in hand with the new Rear Dampers. The new rear dampers are BIGGER and therefore holds more volume (will ideally give the car more turn in yet maintaining rear stabilty).
The Front Damper Stay also allows for different damper positions while using the current dampers.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 11-21-2005, 04:56 PM   #842
Pooh2's Avatar
Send a message via MSN to Pooh2
The yellow clutch shoe works really really GOOD!!!!!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 11-21-2005, 04:57 PM   #843
chemlab's Avatar
The new bulkheads are designed like the serpent 960 for belt tension on front and rear. Although i dont think the 960 does not have the rear belt tensioner....
chemlab is offline   Reply With Quote
Old 11-21-2005, 05:01 PM   #844
Ron C.'s Avatar
Originally Posted by nsupra
Along with the new shock towers they have new front and rear bulkheads, and a
yellow clutch shoe as well. Anyone know any further details on these new items?
The new Bulk Heads make the Front One Way and the Rear Axle ride on Eccentric Hubs (Different Belt Tensions).
The bigger (performance) change on the new Bulk Heads is that they now hold the front one way lower than the stock ones for lower CG.
Old 11-21-2005, 05:19 PM   #845
nsupra's Avatar
Now since the new bulk heads will give different belt tensions will it help prevent the front belt from striping as easy(even though it hasnt been a problem for me)? I know some people were using washers under the mid bearing block to tighten the tension.
nsupra is offline   Reply With Quote
Old 11-21-2005, 05:41 PM   #846
Ron C.'s Avatar
Hi nsupra,
That is correct.
Although like yourself, I personally haven't encountered premature stripping of belts, the new Bulk Heads with the eccentrics should help keep the life of the belts even longer.
Old 11-21-2005, 06:25 PM   #847
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Default front damper mount
There was some talk at the Nats that there is a new body some ran at the worlds that required a lower front shock tower and the use of the MRX3 front arms to enable the body to clear. Can anyone confirm this?
The yellow clutch shoe provides what benefit over the gray, Pooh?
ralph m is offline   Reply With Quote
Old 11-21-2005, 06:45 PM   #848
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
What's the difference between the yellow and the stock grey clutch shoe? I still can't get this 8th to not spin when I accelerate. Either the centax is still to tight (DUNNO HOW...it seems like the adjuster nut is almost off) and or maybe the stock tires lack traction...although I hear the stock tires are fast tires.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 11-21-2005, 10:45 PM   #849
HarKonnenD's Avatar
Default Problems
I realized some things with my MRX4 were completely off and contributed to a few things. First the clutch nut had loosened, but with some parts of the threadlock left on the shaft and adjuster nut still kept the engine running. However it made clutch tuning impossible. I finally got everything disassembled, cleaned, and retightened. For the stock settings rebound it was off and there was a little excess for droop. Another thing that contributed to a lot of rear stiffness. That was also changed to stock settings and now things are a bit more flexible. The rear width on the car was 250mm and shoulda been 263mm with -1.5 toe in. So far so good and now I'm going to do a test run tomorrow to see how this engine runs. Still need to give it another warm up tank as it just passed the 7th or 8th tank (after the 5 break in tanks I gave it) so it's still learning the ropes.
Old 11-23-2005, 08:42 AM   #850
Pooh2's Avatar
Ralph, I'm really not sure about that as of yet. I did'nt get the chance 2 run them back 2 back. The yellow seems 2 last longer and have a lil more snap out of the corner than the grey.
Old 11-23-2005, 09:04 AM   #851
Pooh,
Whats up dog? Getting any racing in down south? See you at the Winternats.
Jamie Corrado is offline   Reply With Quote
Old 11-23-2005, 07:58 PM   #852
What size is the side pulleys on the mrx-4?
Thanks,
Joe
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 11-23-2005, 08:27 PM   #853
Aluminati's Avatar
What are the effects of using this M-1425 Kawahara Aluminum Upper Arm Block on the MRX4? Besides Strengthen the front end of the Mugen MRX4 and it also comes with another set of aluminum blocks which gives more adjustment. My question is in the package it comes with two sets one set is for stock setup and another set has two holes. What happen if you use the block with the two holes?
Aluminati is offline   Reply With Quote
Old 11-24-2005, 09:55 PM   #854
I have the wide belt conversion one way pulley on my MRX4. I noticed that it has a lot of play. Does anybody have the same problem?
manokgt4 is offline   Reply With Quote
Old 11-25-2005, 07:43 AM   #855
nsupra's Avatar
Kawahara 16T and 24T aluminum pulleys. Do you use one of those pulleys for your wide belt conversion?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
