Old 10-16-2005, 03:54 AM   #781
Can someone tell me what is the difference between Standard Clutch shoe and Red Clutch shoe? The option Red shoe costs almost double.
Thanks.
US_MATRIX is offline   Reply With Quote
Old 10-16-2005, 04:56 AM   #782
Also, How often do you replace clutch shoe, centrifugal shoe and the shoe for 2 speed ? I have ran 2 gallons so far and have not changed any of them?
I removed the clutch set and 2 speed but they did not show much in wear off.
Thanks.
Old 10-16-2005, 07:14 AM   #783
sohlman's Avatar
Trader Rating: 89 (100%+)
Can someone tell me what is the difference between Standard Clutch shoe and Red Clutch shoe? The option Red shoe costs almost double. Thanks.
When you say "standard clutch shoe," I assume you mean the gray shoe. They are both good shoes. The red shoe is softer and will give you a very different clutch response from the gray shoe.
Steve Sohl
sohlman is offline   Reply With Quote
Old 10-16-2005, 07:20 AM   #784
sohlman's Avatar
It all depends on your setup and driving style. I know some guys can go thru clutch shoes in a race, but myself, they will last for several races once I get it tuned correctly. I've never replaced my centrifugal shoes this year... maybe I should have but if it works, don't fix it. Now 2-speed shoes can also go quickly depending on when you have it setup to engage. I went through two this season. You'll notice inconsistent gear shifts and/or no shifting at all. Hope this helps.
Steve Sohl
Old 10-16-2005, 06:57 PM   #785
Trader Rating: 23 (100%+)
Anyone know where you can order the yellow rim GRP tires like you saw on the mugen cars at the worlds?
bmcallister is offline   Reply With Quote
Old 10-17-2005, 09:54 AM   #786
Sorry but the yellow wheels were just for the Worlds.
Mike_Swauger is offline   Reply With Quote
Old 10-17-2005, 03:41 PM   #787
Has anyone tried dying the rims? I remember we use to do this in oval back in the ole days. I didnt effect the foam then, of course you werent running the speeds of a 1/8 either.
Old 10-27-2005, 09:37 PM   #788
Default MRX-4 setup for Kissimmee
Per some requests, here's my MRX-4 setup for Kissimmee.
http://www.rollcenterproducts.com/MR...Kissimmee.html
jdesoto is offline   Reply With Quote
Old 10-29-2005, 10:28 AM   #789
Racerboyseven's Avatar
Dose anyone know if somebody is making a front belt tensioner for the mrx 4. My front belt seems to last about a day running at rams club. Is anyone else have this problem, or is it becouse the track is alittle rough or is it me?
I also herd that someone used the after market tensioner for the evolva, and made it fit the mrx 4. Has anyone else herd this?
Racerboyseven is offline   Reply With Quote
Old 10-29-2005, 02:19 PM   #790
Grinder's Avatar
I too had this problem. I put a thin washer under the front of the mid bearing block, one on each screw. No more problems.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 10-29-2005, 04:13 PM   #791
what does this do? Does this twist the belt alittle thus putting alittle tension on it?
Old 10-29-2005, 04:46 PM   #792
Grinder's Avatar
It tightens the belt a little by moving the shaft further away. It does not twist the belt if you use the same size washer on each side.
Old 11-01-2005, 09:53 AM   #793
i am about to put an engine on ebay, but before i do so, i figure i would put it up here first. i am selling a novamega evo6 novarossi engine. it is the same design as the novarossi 321p's (the latest 8 port engine novarossi makes). i had a 1/8th scale but my track went out of business and i never got to run it. the engine was run for one tank. i started the break in for one tank with the car on the starter box. i had to leave and could not finish it. actually jauquin desoto (distributor for mugen) was the one who performed the one tank of starting to break it in. the engine still needs the full break in since only one tank of fuel has been through it. i paid $500 for it. i will sell for $300. i just want to get rid of it, since i do not have a 1/8th car. it is a very good engine. you can email me to [email protected] or call me at 305.807.9529. thanks.
Joe Chaplow is offline   Reply With Quote
Old 11-01-2005, 11:33 PM   #794
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default washers
Quote!! I too had this problem. I put a thin washer under the front of the mid bearing block, one on each screw. No more problems.
what thickness are the washers you used thanks Peter
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 11-02-2005, 03:09 AM   #795
MRX_joe21's Avatar
Send a message via Yahoo to MRX_joe21
The mrx-4 has a lot of steering. I had these a month ago. And somebody set up "AL" 1 degree out, And after my tire and caster swap, I was cuttung through the turns carrying a lots of speed. What impresses me most about these car is watching body react to the suspension movements keeping downforce in the car. Its really cool.
MRX_joe21 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
