Old 09-16-2005, 07:44 PM   #676
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally Posted by JAG Racing
I purchased a Mugen starter box (purple) and I don't see a convenient way to charge the batteries (without unplugging the batteries every time I hook up a charger. Am I missing something? Also, the twin battery packs seem to be having a hard time turning over the engine during start-up; but I'll charge the batteries overnight to really detemine if there is adequate motor torque from the starter box batteries/motor (twin motors).
Do any of you use this "twin pack" starter box? -
I like the 12v battery because it has way more amps. Amps is the key to turning over the engine since your motors get a lotta power from it. More volts has RPM, but not enough power to get the motors going. The 12v also last a lot longer through runs depending on how you use the box. My failsafe currently sits on the transponder mount. No transponder in my posession as yet.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 09-16-2005, 09:07 PM   #677
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Hey Harkonnen - My twin packs produce up to 14V @ 3 Amps which should be plenty of juice I would think. I have a 12V gel-cel rated at about 12 V 4 Amps so I think I just need to charge if with enough current -- we'll see this weekend. I do have a gel-cel as a back-up BUT I really like the lightweight of the twin packs! I was hoping that someone could confirm that the twin packs are adequate. (3000mA per pack)
JAG Racing is offline   Reply With Quote
Old 09-16-2005, 10:22 PM   #678
HarKonnenD's Avatar
Oh sweet 3000mah thats a different story. Just one amp short of the 7amp batt i have. In that case those will work great.
Old 09-17-2005, 06:11 PM   #679
where are the new hop ups available for purchase. I cant find any shops with them. Whats the best place online to order mugen parts?
bmcallister is offline   Reply With Quote
Old 09-17-2005, 06:23 PM   #680
rcmike's Avatar
Trader Rating: 40 (100%+)
try nitrohouse.com ace-hobbies.com
rcmike is offline   Reply With Quote
Old 09-19-2005, 12:11 PM   #681
Does anybody had wabley problems running twister tires. I know it's the tires coz if i put in kawahara's or GRP's the wable problem is gone.
Thanks..
manokgt4 is offline   Reply With Quote
Old 09-19-2005, 12:13 PM   #682
cdelong's Avatar
Yes- I notice they are a little "loose" on the MRX-4. Kinda a bummer, cause the prices are good on Twister's.
cdelong is offline   Reply With Quote
Old 09-19-2005, 12:31 PM   #683
I like those tires too. It seems to be very solid and not to mention the price is aweasome!!
But is their a way we can fix that problem though? i wonder if it also affects other cars like evolvas and the 960?
Old 09-19-2005, 01:04 PM   #684
cdelong's Avatar
I was just at the Midwest Series race in Toledo, OH, and Kyosho and Delta drivers have experienced the same fitting of the Twister tires- loose.
I'm not sure it can be fixed unless they change rim styles.
Old 09-19-2005, 11:25 PM   #685
JAG Racing's Avatar
Default Optional Rear Upper Arms (H0147)
I decided to go ahead and install the optional rear arms. Any suggestions on which mount to use for starters? H0147B or 147C. Longer arm or shorter arm?
Old 09-22-2005, 02:05 AM   #686
try http://www.ashfordhobby.com/pricing009.htm
Yea it's good to do your hop-ups now in the process of putting the kit together. That's what I did...
rhed is offline   Reply With Quote
Old 09-22-2005, 02:39 AM   #687
PRospeked's Avatar
speaking of rear arms. Has anyone got any suggestions of a good tool to use to adjust them. Its a total pain to do it with allen keys.
PRospeked is offline   Reply With Quote
Old 09-22-2005, 08:05 AM   #688
HarKonnenD's Avatar
Get allen wrenches. They are the best thing. DOWN WITH ALLEN KEYS!!!! Those things are horrible and leave your fingertips in bad shape.
Old 09-22-2005, 09:27 AM   #689
Start with the shorter arms first and then if you need more sidebite then go to the longer arms. The H0147 arms in the short position are longer then the stock arms.
Mike_Swauger is offline   Reply With Quote
Old 09-22-2005, 10:33 AM   #690
afiq's Avatar
Hi mike!!!
Got a few question;
on heats and final usually u ran how many mm on your ride heights (smooth and flat surface)
i got a problem when i punch out of the corner my car slighty tail.
thanks mike.
afiq is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
