Old 05-20-2005, 08:39 AM   #481
1fastdude's Avatar
Trader Rating: 15 (100%+)
Normally multi-ring tires will last a little bit longer than non multi-ring. Also the shore will be a little higher, due to the glue on the multi-ring. You should have more grip with non multi-ring tires!
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is online now   Reply With Quote
Old 05-20-2005, 10:33 AM   #482
teammpp's Avatar
Multirings do last longer but they also provide more grip. The reason being you can run a shore lower than normal due to the lower wear rate.
in general multirings are far superior to normal tires. problem is not many people can get hold of them. best thing to do is buy foam donuts and make your own. try mixing shores and run a shore higher on the outside.
teammpp is offline   Reply With Quote
Old 05-20-2005, 12:09 PM   #483
trashcar's Avatar
Default multi ring
Fastone I'm with you,Multi ring longer wear slightly less grip. No such thing as a free lunch,never seen a trade off of better wear AND better grip.
trashcar is offline   Reply With Quote
Old 05-20-2005, 01:54 PM   #484
nils's Avatar
now im confused.
when do you drive multyring,and when do you drive the normal wone?
and witch wone is better?
by the we.www.enneti-tyres.com they have multyring,s
nils is offline   Reply With Quote
Old 05-20-2005, 02:44 PM   #485
teammpp's Avatar
Originally posted by nils
now im confused.
Which track in holland do you race at? My personal experience of European tracks (nearly 20yrs) has shown that Multirings are the best tire to use. It possible that they dont work as well on painted out parking areas etc compared to the purpose laid tracks in Europe.
Old 05-20-2005, 03:19 PM   #486
nils's Avatar
hello mister pallaris,i only drive race tracks.
i drive at.
www.evmc.nl
www.macdebaanbrekers.nl
www.mach.nl
www.mbcdesluis.nl
www.raco2000.nl
www.real80.nl
www.amcaracing.nl
you should look at these site,s these are the big race tracks in the netherlands.
im a member of the sluis club in gouda it is in central holland.
by the we they sel multyrings from enneti at www.hobbiesireland.com.
Old 05-20-2005, 03:22 PM   #487
nils's Avatar
sorry for spelling your name wrong mister palmaris.
Old 05-20-2005, 05:23 PM   #488
teammpp's Avatar
i drive at.
www.evmc.nl
www.mach.nl
www.mbcdesluis.nl
www.raco2000.nl
www.real80.nl
www.amcaracing.nl
I have seen several of the dutch tracks. Mach, amca, and a couple of others. We are planning a trip over at some stage. I have loads of 1:8th Multirings but find it hard to get 200mm versions. I usually buy foam donuts and make up my own 3 ring multishores.
Old 05-21-2005, 01:45 PM   #489
nils's Avatar
do you no the brand gp tires they have multiring and multiring shore from sotf inside to hard outsite for the 200mm class.
Old 05-28-2005, 12:26 PM   #490
nils's Avatar
he harkonnenD this is the mrx4 forum.
for al your information.
Old 06-03-2005, 06:36 PM   #491
shock measure?
Leaving of I begin it that the shock absorbers must have a measure which are the measure that I put in my shock absorbers, since the manual nothing relates, (for measure understands length of the shock absorbers)
pmvalente is offline   Reply With Quote
Old 06-03-2005, 10:42 PM   #492
Cat Skinner's Avatar
Lightbulb
I'm not sure that I understand the question but here's a pic and some info.
The size that I think is about right is between 66.5mm to 67mm measured from the top to the bottom, make sure that all your plastic is uniform. The way that I understand it what's really important is that the rear are a set and front shocks are a set. Should be long enough not to get in the way of your the rebound stops.
If anyone has better info please jump in.............
Cat Skinner is offline   Reply With Quote
Old 06-03-2005, 11:13 PM   #493
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default shocks
yes make sure that after you set the droop(with the shocks removed) that the shocks should compress a little to screw them on. if you have to lift the arms to mount the shocks you have to lenghtened them. make sure they are equal lenght right and left
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 06-03-2005, 11:22 PM   #494
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Ahh so here is the MRX4 forum. Kewl. Guess I'll fit right in here just fine with my MRX4.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-04-2005, 03:24 AM   #495
Default shocks
ok guys, because I had a Serpent 950R and in serpent they have a specific measure to each pair of shocks, front 67.5 and rear 76.5, thats because I'm asking.
thanks anyway.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
