Old 03-28-2005, 01:24 PM   #391
nils's Avatar
Default can some wone explain the lower arm position,s
can any wone explain to me ,when to use a difrend size
of lower arm mounts,wy are there 3 size,s 4.5 5.5 6.5.
please tel me when to use witch size ,for what track to use.
nils is offline   Reply With Quote
Old 03-30-2005, 07:53 AM   #392
Chewdogg's Avatar
nils,
Someone ask a similar question on the mugen forum and here is Swauger's response.
...If you go to 6.5mm block in the rear you will get more side bite and if you want the car to rotate more in the corner you can go to the 4.5mm block.
Chewdogg is offline   Reply With Quote
Old 03-30-2005, 07:55 AM   #393
Chewdogg's Avatar
Does anyone know if the MRX3 Rear dogbones will fit the MRX4?
Old 03-30-2005, 09:03 AM   #394
Pooh2's Avatar
Send a message via MSN to Pooh2
Nope the mrx3 dog bones r shorter than the mrx4.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 03-30-2005, 09:14 AM   #395
Chewdogg's Avatar
Bummer.....
thanks Pooh2
Old 03-30-2005, 09:23 AM   #396
cdelong's Avatar
Originally posted by Chewdogg
Bummer.....
thanks Pooh2
Thats funny cause the MRX4 rear axles have the same part number as the MRX3 axles (H0222). Rear CVA's also have the same part number (H0276) as the MRX3. I'm betting they will work.
Fronts also have the same part number (H0270).
Lee Muse from Winner's Circle has compiled a list of common parts on his website.
http://www.gasrccar.com/
belts, CVA's, front one- way, suspension shafts, bumper, front uprights, and all clutch gear parts are interchangeable. Just do a comparison of parts list between the two cars.
cdelong is offline   Reply With Quote
Old 03-30-2005, 09:46 AM   #397
Pooh2's Avatar
They really don't the mrx4 has longer arms and longer dogbones. But do what u want it's up 2 u.
Old 03-30-2005, 09:55 AM   #398
Chewdogg's Avatar
I just checked gasrccar list the MRX4 rear bones as an unique part D0291 I think the MRX3 part # is D0219.
Old 03-30-2005, 10:01 AM   #399
cdelong's Avatar
I stand corrected on the dogbones as I quoted the axle part number- not the half shaft (dogbone).
Multiple sources still list the front and rear CVA's the same part number (H0270 and H0276) as I stated.
Old 03-30-2005, 10:03 AM   #400
Pooh2's Avatar
Pooh was right.
Old 03-30-2005, 10:23 AM   #401
nils's Avatar
Default question about the new huddy 1/8 set up system
i have a problem with the toe gauge ,it wont fit on the front
alu stands,is eny wone having the same problem with this toe gauge.
it fits one the rear,but not on the front,i think the machined slots
arend wide enof.
Old 04-01-2005, 08:10 AM   #402
A friend of mine had the same problem...
Apparently there is a problem with the basic set-up system.
He took his basic system back to his LHS and they were kind enough to open all the other basic systems to find the same problem.
They tried opening the 'All in one solution' and it had the correct sized toe gauge. He didn't want to spend the extra $ on the All In one, but is now happy he did! The tweak board reveals all!
Brooklyn Hobbies 718-951-2500 has stacks of them at a great price and will not be selling any more basic systems until they are all replaced.
NitroHead is offline   Reply With Quote
Old 04-01-2005, 03:15 PM   #403
nils's Avatar
Default not 0nly the toe in gauge but olso the caster
hello nitro head,not only the toe in gauge,but olso the caster
scale isn,t correct it only go to 10 deg. it should go to 20 or even
more.please tel your local store dealer to contact hudy.
so that they solve the problem .
ps ceap me informt.
Old 04-01-2005, 08:28 PM   #404
Nils,
You need to return your basic system and get the all in one sys.
Old 04-02-2005, 02:37 PM   #405
nils's Avatar
Default hello nitro head
i have the exclisive set up system the wone with the alu stands.
it is the same system as the all in wone,but with out the tweak
station.
if you set the car by the factory set up sheet that came with the kit,you wil see that it dosnt fit,and you can not read the ful caster
scale if you have the upper arms laid back then it should be around 30 ore 40 degrees ,and the stands scale for caster only
go,s to 10 degrees.
you can theck it out with your mrx4.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
