Old 09-07-2006, 01:04 PM   #1516
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
Don't use nitro clean or WD40 on bearings, it will remove the grease from the bearings which is very importent.
Use proper bearing grease, not ARO or WD40 or Nitro clean.
Fsturbo15 is offline   Reply With Quote
Old 09-07-2006, 09:47 PM   #1517
Trader Rating: 13 (93%+)
Thanks for your help guys
i was new to rubber sealed bearings and not sure of their maintenance
you guys cleared this up. thanks heaps!
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-08-2006, 12:14 AM   #1518
asw7576's Avatar
There is some point you need to clean inside the bearings and re-lube them again.
Serpent premium lubricants are good too because it's not too thin.
Old 09-08-2006, 12:16 AM   #1519
asw7576's Avatar
Originally Posted by MugenDrew
I use an Indy sparkle(integy) or a small jewlery cleaner(ultra sonic) and parts washing fluid from an auto parts store. You can also round the tip of a hobbie knife blade to remove the rubber seals. Metal shielded require a little more effort. Look at the outside edge of the sheild and you can see the about half of the clip. Follow this around until you see the gap. Look at the ends of the clip and one end will be angled so that you can get a stick pin behind its edge. Dont stab your self and be gentle so you dont send the clip flying. I remove all the grease clean and lightly reOIL. Running on clean tracks I'll do this every two to three races.
I wish I have ultra sonic cleaner
What kind of liquid do you use with ultra sonic cleaner ?
Old 09-08-2006, 06:58 AM   #1520
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Cold parts cleaner, parts washer fluid from an autoparts store. Do not use the carb cleaner. They sell it in one gallon buckets it is not a spray. The jewlery cleaners are like 15 bucks at walmart,target etc. the Indy sparkle is on www.integy.com.
MugenDrew is offline   Reply With Quote
Old 09-10-2006, 02:25 AM   #1521
MugenManiac's Avatar
Default Floyd Bennet Field
Will Floyd Bennet Field be open tommorow? or will there be races?
MugenManiac is offline   Reply With Quote
Old 12-05-2006, 02:20 PM   #1522
quietstorm76's Avatar
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 01-25-2007, 10:29 PM   #1523
Default need more top end..
hey guys
i was at our track today and i feel that the mrx-4 needs more top end..
it was peaking out rpm at 3/4 down the straight.. i even tried adjusting the 2 speed to shift later.
the bottom end was fine..wats a good gear combination i can use to get more revs in the top end?
im using a os vz-r version 2 engine..could it be the engine maxing out rpm?
thanks
john
Old 01-26-2007, 04:25 PM   #1524
Any recommendations on MRX 4 pully ratios ? im loking to get the kawahara pullys .. Front teeth combos im interested in...
Emtypunzo's Mum is offline   Reply With Quote
Old 01-26-2007, 04:39 PM   #1525
cdelong's Avatar
26T front side pulley. Don't bother with the aluminum pulleys unless it's the small one on the inner front layshaft. I have one for a one-way if you really must have one. Cheap......
Just stick with the stock plastic stuff.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 01-27-2007, 09:03 AM   #1526
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally Posted by mrgsr
hey guys
thanks
john
What pipe are you running with it? I know this motor isn't much of a beast on top end, but for the small to medium sized tracks is pretty decent. Infact, how big is your track? I'd step upto the Mega ZX21 '06 version if you want something inexpensive, but will hang with the other motors. I saw that most racers aren't too far off from the stock gear ratio on the MRX4 and or just change from the 17T pinion on first gear to the 16T.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-27-2007, 09:22 AM   #1527
captian's Avatar
no !!!! details on the site
http://www.phpbbserver.com/fanaticre...anaticremotera
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 01-27-2007, 09:25 AM   #1528
captian's Avatar
the site has more info on the racing coming up this year but the track is open for testing but its freezeing
Old 01-28-2007, 05:02 AM   #1529
Hi
thanks..im using a novarossi pipe its a 2015 with 3 fin header.
the track has 19 corners and 1 long straght with a sweeper at the end. im thinking of getting the vzr modified to increase the top end. it was cheap to start with..
im trying to find a piston liner for my m-rossi rex pr350 that should have heaps of power to get around.
Old 01-28-2007, 09:54 AM   #1530
Joe Tanto's Avatar
Default diffs
hi any body can tell me what diff oils I can use .front and .rear???
Joe F
Joe Tanto is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
