Old 08-25-2006, 07:53 AM   #1501
ElectricConvert's Avatar
I believe this just centers the rear body mount as the chassis travels vertically ensuring you have equal downforce on both rear wheels.
ElectricConvert is offline   Reply With Quote
Old 08-25-2006, 12:06 PM   #1502
Originally Posted by Corse-R
Today I've been at my local track and faced a very strange thing with my 4-R, here's the scenario:
- Mugen Dome body (Kyosho one), gurney flap at 3mm over the body.
- 1degree toe-out front.
- 2.5 degrees camber at Front and 3 at rear.
- White spring with #600 oil (F/R).
- 2 degree toe-in at rear.
- Long rear upper a-arm
- Shocks at their stock positions
- 1mm shim at the rear uprights.
- Front roll bar at around 40
- Rear roll stock with 3mm of hang over the balls (stock setup).
- A ackerman.
- 35 shore all around.
Car has a massive understeer coming out the turns and feels too nervous on entering the turns.
Solved it partially giving it more caster (in fact I have only the 1mm shim at rear of the a-arm) but spanks the front tyres giving me a pretty inner lip the outer side is almost brand new.
Could not test this morning but wanting tomorrow to test:
- B Ackerman.
- Giving less camber at the fronts
- Go to med rear a-arm.
- Red springs at rear
Suggestions please? Track is big and flowing, gear ratio is 17/49 and 21/45. Only two hairpins the rest are flowing turns.
Try the B ackerman, and the short rear upper arms,as well as two shims in the rear uprights.
are you using the 4.5mm roll center block or the 5.5mm??
try the 4.5mm one.
it seems you have way too much camber in the front, use only 0.5 -1.00.
good luck!!
AKSHUN is offline   Reply With Quote
Old 08-26-2006, 02:07 AM   #1503
Try a Lola body. More forgivig than a Dome. Ride height could be to high in front and flaten the front sway bar.
jake alton is offline   Reply With Quote
Old 08-26-2006, 02:12 AM   #1504
Corse-R's Avatar
Jake, Akshun: The problem was solved, was a miss chossing the tyre split the culprit of the oversteer. With 7 milimeter of split, everything is fine.
Akshun: I need such quantity of camber, if not, the front tyres hook-up too much during cornering and you can do a pretty much big flip (but going to reduce them to 2 degree the next time). On my track, you spend a lot of time in serious cornering. The most by far tyre who suffers is the rear right tyre, choosing a shore higher is common to compensate the massive wear who suffers that tyre. The next is the front right.
When grip goes up (and we've seen some nice traction rolls with 1/8 cars), is normal to put 37's on the outer (right) and 35's on the inner side (left).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-26-2006, 07:02 PM   #1505
I hear ya corse, on my track, we also have uncontrollable wear on the right rear.
have you tried using your font sway bar to eliminate some of the tight cornering.
also , sounds like you guys have lots of traction, what about trying the short wheelbase set-up??
good luck!!
Old 08-26-2006, 07:35 PM   #1506
cdelong's Avatar
good luck!!
Steve,
Looking at my car from the rear, the left rear always wears more. I had a 2mm difference after last weeks Can-Am 30 minute main. Same on the front.... just about a 1mm difference though.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 08-26-2006, 10:14 PM   #1507
Corey, the slower cars always wear on the left side.
Old 08-26-2006, 10:39 PM   #1508
cdelong's Avatar
Or maybe is that a Metric left vs. American left??? Low blow ....... but I'll be nipping at your heels after the next club race.
I have a real good story for you at the track next time- from the Can-Am race. It's a similiar situation to a particular person in our heat at the GLC.
KYOSHO EVOLVA
35PLUS21
Old 08-27-2006, 11:28 AM   #1509
It's go time!!
see ya at the next race
Old 08-27-2006, 07:25 PM   #1510
Trader Rating: 15 (100%+)
What does changing the rear upper link do if you put on the short, med, or long?
THE DOCTOR is offline   Reply With Quote
Old 09-07-2006, 12:34 AM   #1511
Trader Rating: 13 (93%+)
Default cleaning the standard mrx4 rubber bearings...
heys guys
how often do you guys clean your bearings ?
I race on a very clean track but sometimes i go into the grass infield haha.
also, i have never cleaned rubber bearings so how do you go about doing this ? thank you
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-07-2006, 02:42 AM   #1512
Corse-R's Avatar
Originally Posted by mrgsr
heys guys
At least before a big race, a complete teardown and cleaning of the bearings is mandatory... meanwhile after 3 or 4 times I'll go to the track for practice, the bearings are completely cleaned, each time the car touches the track and leaves, a cleaning with compressed air (trackside) and serpent putty (homeside) is what I do, then... a dab of oil on the needed places and until the next time.
Cheers,
Corse-R
Old 09-07-2006, 02:45 AM   #1513
asw7576's Avatar
heys guys
You can peel off the seals with thick needle. Insert the needle from inside hole section and peel it off. Need sometime to practice.
You can use WD40 to spray and soak the bearings ( 30 minutes ). Shake them and spray again until you think is clean. You can spray with motor cleaner or soak them with nitro fuel for finishing touch.
Tamiya ceramic grease is the best lubricant for bearings. Fill it until max and close the seals.
I do this every 4 race meetings.
Main Pulley Shaft Bearings and Rear Diff Bearings need early maintenance maybe every 2 race meetings.
Old 09-07-2006, 11:19 AM   #1514
MugenDrew's Avatar
Trader Rating: 30 (100%+)
I use an Indy sparkle(integy) or a small jewlery cleaner(ultra sonic) and parts washing fluid from an auto parts store. You can also round the tip of a hobbie knife blade to remove the rubber seals. Metal shielded require a little more effort. Look at the outside edge of the sheild and you can see the about half of the clip. Follow this around until you see the gap. Look at the ends of the clip and one end will be angled so that you can get a stick pin behind its edge. Dont stab your self and be gentle so you dont send the clip flying. I remove all the grease clean and lightly reOIL. Running on clean tracks I'll do this every two to three races.
MugenDrew is offline   Reply With Quote
Old 09-07-2006, 11:28 AM   #1515
Lil Paul's Avatar
Default Compressed Air
I usually blast my bearings bone dry with nitro blast and then give them a drop, and I mean one drop of trinity bearing oil. As with anything else, you have to do what you feel is best for you. One thing is for sure, you must be careful when using a compressor to blow off your car, I try not to blow in the direction of my hubs/uprights. This will only blow more dirt and grit into the bearings. Other bearings are for the most part pretty well hidden, but those I mentioned are exposed.
Lil Paul is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
