Old 08-07-2006, 01:45 AM   #1486
ND
Originally Posted by quietstorm76
Is adjustable wheel base an option on the MRX4 and if so how do you do it?
Hello
Yes the MRX4 does have adjustable wheel base, there is a shim that you place on the front lower wishbones, it's a bit like a caster shim, so you can change wheel base very quickly. When you change this shim you need to alter the shims on the upper wishbone the same amount or your going to get a big change in caster settings.
ND is offline   Reply With Quote
Old 08-07-2006, 01:50 AM   #1487
ND
Originally Posted by mrgsr
hey guys im kind of still new to 1:8
what does the the adjusting screw at the back of the car thats in the middle of the rear body support do ?
when adjusting the screw the scew you can move the part up and down. i noticed it limits or adds chassis up travel..
is this clear at all? sorry for the bad explanation
Hi
All this part really does is keep the body mount central, some times in a big accident this pops out and the body sits all skewed.
As for adjusting it, make sure it doesn't limit the suspension travel, or you will have a car that has some problems with rear end traction. It's not something we adjust to change the car set-up.
Old 08-07-2006, 01:55 AM   #1488
Trader Rating: 13 (93%+)
thank you very much for your reply
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 08-07-2006, 04:46 AM   #1489
quietstorm76's Avatar
Originally Posted by ND
Hello
Ok so the thick upper arm spacer moves with the lower arm spacer. It not used as a caster adjustment. I understand now. Thanks
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-07-2006, 08:45 AM   #1490
M7H
M7H's Avatar
Originally Posted by Corse-R
Doh!... during the dissasembly and checking my notes, found a thing very very embarrasing...
Been running all the day with only 6mm split when the car needs 7... this could be the main cause for the understeer...
That might be it......
See, it's so easy to overlook something......
Serpent
M7H is offline   Reply With Quote
Old 08-10-2006, 07:41 PM   #1491
the fuel tank on my mrx4 does not hold 125cc not even close I found this out at the GLC trying to make 5 mins
does the new mrx4r tank hold 125cc?
thx
Lou
look is offline   Reply With Quote
Old 08-10-2006, 08:51 PM   #1492
cdelong's Avatar
thx
Lou
Lou...
tanks are hit and miss on volume. we'll try to expand your tank with some compressed air on saturday.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 08-13-2006, 07:16 PM   #1493
Originally Posted by shortfatguy
I made sure that the thrust bearing was lubed well. It only took about a tank and a half to fry it. The bell gap seems to be ok, anything else that could be the culpret?
I did change the spring from the silver one in the kit to the gold one so it would be a bit stiffer. So far I have fried two with the silver spring and one with the gold.
I have had similar issues with my thrust bearings.Remove the clutch bell, check both of the bearings surrounding the bell, make sure they are free and clean, make sure your spring nut is not too tight or too loose, check the washers surrounding the thrust bearing, one of them has a slightly larger hole, it must go closest to the motor side(on first) if your running the ninja motor, you should use the ultra hard spring, the kit comes with the super hard spring.
hope this helps.
steve
AKSHUN is offline   Reply With Quote
Old 08-14-2006, 07:15 AM   #1494
does anyone know where i can find setup sheets from factory drivers for this car on various tracks?
thx
Lou
Old 08-14-2006, 02:46 PM   #1495
LOOK at www.mugenracing.com under Setups !!!
Easy as pie ...and chips
Crashtopher is offline   Reply With Quote
Old 08-14-2006, 03:41 PM   #1496
I tried that link and found no setups ??
Old 08-14-2006, 06:14 PM   #1497
cdelong's Avatar
http://www.mugenseiki.com/menueefi.htm
not much posted in the form of recent setups.......
You're better off PM'ing Ron C. here. He's really helpful
KYOSHO EVOLVA
35PLUS21
Old 08-24-2006, 12:59 PM   #1498
TonysScrews's Avatar
UPDATE!
Mugen MRX4R 1/8th On-Road screw kits are now in stock!
Mugen MRX4R 1/8th On-Road 232-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, lock washers and set screws.
Kits will begin shipping today, August 24th, 2006.
Thanks and best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 08-24-2006, 05:18 PM   #1499
The screw will also help to stablize or lossen up the rear end so be carefull if the screw is pushed up it will tighten up the rear end if its down it will loosen up the rear end. Try it; you will notice the difference.
jake alton is offline   Reply With Quote
Old 08-25-2006, 07:21 AM   #1500
MugenDrew's Avatar
Trader Rating: 30 (100%+)
You are using this screw to adjust downward/upward chassis travel? Should be set in the middle with the car resting as it would on the track. This ensures that droop/rebound and downstop are being controled by the 3x5 mm screws in the arms.
MugenDrew is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
