Old 05-04-2004, 01:18 PM   #1
Default Tuning problems – HPI Rs4 Nitro Star 15FE
I bought a HPI rs4-3 from a friend of mine, It has a pretty new engine, it was broken in and doesn’t have that much run time on it. When I first drove the car it started right up and ran fine. After about one tank of gas I refilled the tank, the car wouldn’t run right after this, I refilled with new gas with 20% nitro.
I went to HPI’s web site and found the tuning instructions and found that the needle needs to be three turns out, then fine tuned from there. I set the needle and when I try to start the car nothing happens. I will prime it twice and it starts (just rev’s really high for about three seconds and then die’s). Then I will try to start it again and it won’t start till I prime it again. I have played with the needle and can’t get it to idle or stay running; it just revs way up then dies.
The exhaust line is hooked to the gas tank and doesn’t seem to be any leaks. I have also replaced the glow plug, I notcied that there was gas coming out of the carb where the air filter goes, Can anyone help???? -Nick
ntonar is offline   Reply With Quote
Old 05-04-2004, 01:33 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Tuning problems – HPI Rs4 Nitro Star 15FE
it sounds like you have it too lean try richening the mixture a couple of clicks (counterclockwise)
Old 05-05-2004, 12:28 PM   #3
Rapid Roy's Avatar
Also check the screw the holds on the carb arm. It's a bit hard to see if it has come loose.
Rapid Roy is offline   Reply With Quote
Old 05-05-2004, 01:23 PM   #4
j240z's Avatar
I had this happen to me twice in the past. Put some thread lock on it and tighten it down good. After that my 15fe ran great and was always easy to tune and very reliable
j240z is offline   Reply With Quote
Old 05-12-2004, 10:18 PM   #5
Send a message via AIM to finbone
i used to race a 15fe. 3 turns is flooding it. go 2 and1/2 turns from closed, then turn it to the right 3 clicks. the engine will run around 220 degrees and scream.
finbone is offline   Reply With Quote
Old 05-13-2004, 01:21 PM   #6
Rapid Roy's Avatar
Thats terrible advice. Each engine tunes differently depending on ambient temperature, humidity, fuel, and many other variables. There is no magic turn setting for the carb. You should always start out on the rich side and lean out 1/8 of a turn at a time, keeping an eye out on the temperature
Old 05-13-2004, 06:15 PM   #7
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
ntonar: Check the 2 screws the hold the carb on! They do come out and they do cause the exact symptom that you are explaining. HPI says dont thread lock the carb screws but you have to or they will fall out. At what point do you take the ignitor off?
HAHA your funny...it might work to be that lean if your temps are like those in Alaska.
I run mine between 3.25 and 3.5 turns out to keep it from overheating.
corvettecrazy is offline   Reply With Quote
Old 05-13-2004, 09:46 PM   #8
in 80 degree weather it ran 220 degrees and would run with the o.s.'s and rossi 12's. it all depends on the placement of your cooling holes and the heatsink head. making sure it is always clean like all real racers do
WTB: HPI 15FE (.15) Nitro Engine VasMan R/C Items: Wanted to Buy 1 04-24-2007 08:29 PM
Tuning Problems RCMASTA Electric Off-Road 5 01-03-2006 06:59 PM
roto star problems t1bmxrder Rookie Zone 9 10-21-2005 10:09 AM
HPI Nitro Star .12R XS tuning help WeatherB Onroad Nitro Engine Zone 4 06-05-2005 05:27 PM
HPI Star .12 SS Engine tuning questions UNITED_RC Nitro On-Road 1 12-29-2003 10:32 PM
