Old 05-12-2010, 05:04 AM   #1
Default i have a mystery problem
alright i have a mugen mrx4x it runs fine but it doesnt like the sir clip or eclip whatever u call it it decides to throw it off witch leaves teh 2 speed assembly falling off what do i do to make the clip stay on
Daniel1234 is offline   Reply With Quote
Old 05-12-2010, 05:21 AM   #2
Trader Rating: 18 (100%+)
Default problem
Either it is the incorrect size clip, or the groove in the layshaft is not deep enough.
They now have new clips out that have right angle taps on them that makes removal and installation very easy.<screw drivers are no longer needed to remove these new clips>
Kamikaze Toys and Hobbies carries these and they work great.
I use them on all of my cars. <Mugen MRX4X, Mugen MTX4R, Serpent 966>.
Contact Sam at Kamikaze <racing forum> and he will hook you up
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 05-12-2010, 06:25 AM   #3
it snaps on its the correct size its done this twice in 2 days now making it hard to run the motor in
Old 05-12-2010, 06:26 AM   #4
PROVK's Avatar
Trader Rating: 14 (100%+)
Its called an e clip, just replace it with the correct sized one.
I always replace mine for insurance as they do loosen when removing and replacing all the time and with the right sized screw driver they come off very easy
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 05-12-2010, 06:40 AM   #5
they were both brand new e clips one went for about 10 meters the second went for about thirty
Old 05-12-2010, 06:48 AM   #6
wingracer's Avatar
Trader Rating: 24 (100%+)
I have never had this problem with the two speed shaft but I did have a pully do the exact same thing. Replaced the adaptor and all was fine. So, try getting a new shaft.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-12-2010, 06:52 AM   #7
will do ill get one and post back
Old 05-12-2010, 04:50 PM   #8
Wanabrc's Avatar
Trader Rating: 70 (100%+)
I'll second that. If new clips keep falling off, the shaft is worn.
Wanabrc is offline   Reply With Quote
Old 05-12-2010, 06:04 PM   #9
Zootcapri's Avatar
I've had to push the shaft up a little (play) to make room to get it to seat right. Pushing the shaft from the side belt side.
... more fun than we should be allowed.....
Zootcapri is offline   Reply With Quote
Old 05-13-2010, 03:46 AM   #10
thanks for all your help much appreciated
Old 05-13-2010, 05:26 AM   #11
Roelof's Avatar
Send a message via ICQ to Roelof
Yes, get a set of circlips and you can last them for ever.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 05-13-2010, 05:49 AM   #12
its a brand new car the shaft isnt worn its been run for like 3-4 min
Old 05-13-2010, 06:21 AM   #13
Never use a needle nose pliers to put an e-clip on. It is too easy to deform or strech out e-clip. If your e-clip go on easy it is too big and if it is a real pain to get on it is too small.
speedster1919 is offline   Reply With Quote
Old 05-13-2010, 12:57 PM   #14
it's supposed to work perfectly, you must be doing somthing wrong.
make sure the clip is falling into the groove slot, and not just going over the shaft.
sometimes you have to push the shaft from the "side pulley" side to see the groove it's to fall into.
if it still falls off maybe you have the wrong e-clip
yappy is offline   Reply With Quote
Old 05-16-2010, 05:30 AM   #15
its all good now i added about a 2mm gap between the e clip and 2nd gear module and hasnt come off since thanks for all your help guys
Kyosho GX 15 Engine Problem RadioOne Nitro On-Road 10 07-28-2008 02:03 AM
FK05 mystery wcalaker Electric On-Road 26 02-19-2007 10:46 AM
more info needed on this mystery car tl01 1989 Electric On-Road 32 04-20-2003 08:36 PM
