Old 05-11-2010, 03:25 AM   #1
Default need just a little help
hi i recently bought a mrx4x and a team orion crf .21 that was easy putting all that together its just the tuning
i have the motor running i can ally the braked and it will stay at idle without stalling but when i got to apply the throttle agin it will stall
then i manage to stop it stalling but have to apply throttle slowly i have no idea if its the clutch or the 2 speed but the wheels dont turn after this stage when i start it on the starter box wheels are spinning fast what should i do
Daniel1234 is offline   Reply With Quote
Old 05-11-2010, 04:44 AM   #2
Pattojnr's Avatar
Trader Rating: 19 (100%+)
sounds like your clutch is always on. also check your radio is all setup right.
when you are in nuetral, the carb shold be closed all the way, if you apply brake, the carb shouldnt close any more. if it does your servos need to be setup better in neutral. when your engine is running, your cluth bell shouldnt be spinning at all. if its spinning, then have a look at how to setup your clutch better, http://www.youtube.com/watch?v=7wjog...ayer_embedded#! see if this helps .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-11-2010, 05:03 AM   #3
thanks for that very helpful
A little help with my new engine ffd173 Monster Trucks 60 02-18-2007 01:01 PM
NEED A LITTLE HELP PLEASE! [ELLiPSiS] Australian Racing 35 06-08-2006 03:58 PM
Eagle CDC Ver 6 Charger. Need a little help... Kennedy Australian Racing 12 10-29-2003 07:54 PM
