Old 05-11-2010, 08:18 PM   #16
Turbo9000's Avatar
Originally Posted by tetris View Post
Well, I manufactured a under-carriage from aluminum sheet metal today. Took all day, but I finally got it done. It fits the shape of the chassis perfectly, and folds around the main/long belt and also around the spurs/pinions/flywheel section, behind the receiver. I milled a cutout for the flywheel for starting. It screws into the bottom of the chassis in 5 places to keep it held securely.
I will test it out tomorrow and see if it actual helps.
Also, what about just coating foam tires with this instant rubber in a can stuff? It might work OK for a run, and then you can cheaply redo it.
http://www.plastidip.com/home_solutions/Super_Grip
http://www.plastidip.com/home_soluti...cal_Insulation
http://www.plastidip.com/home_solutions/Plasti_Dip
Try capping old foam tires with bike inner tubes. works great. Thats how ive always done it.
Turbo9000 is offline   Reply With Quote
Old 05-17-2010, 02:42 PM   #17
tetris's Avatar
I see what you mean. Stretch the inner tube over the tire so the foam is inside the tube. I was thinking about wrapping it around, but then there would be a line where it was glued.
Sounds like a good tip!
tetris is offline   Reply With Quote
Old 05-17-2010, 03:13 PM   #18
Turbo9000's Avatar
Yes sir!
What i usually do is take a 26'' mountain bike tube, or 20'' BMX tube (any tube with a large diameter cross section) that way you wont have to wrap it around and have a seam... Just pull a cross section of tube over the foam and glue it.
you can get "puncture proof" tubes that are about 1/8'' thick, so you also have options with that & if you want you could cut grooves in the rubber if you have a lathe, that way you will have rain tyres.
Old 05-25-2010, 02:51 PM   #19
PMT Tyre used to make a full rubber belted tire for the 1/8th on road. I have 2 pairs somewhere in my tool box rear wide and narrow front. The only problem was finding the correct foams to use.
Twisted_Metal is offline   Reply With Quote
Old 05-25-2010, 03:00 PM   #20
Zootcapri's Avatar
I want to try it. I have a box of used tires and several innertubes. What glue are you using? CA? rubber cement?
... more fun than we should be allowed.....
Zootcapri is offline   Reply With Quote
Old 05-25-2010, 03:21 PM   #21
Turbo9000's Avatar
I cant remember the specific number, but its a loctite adhesive that came in a syringe type tube, there was also an aerosol activator you spray on before applying the glue.
I dont know if that glue was a good choice or not, it worked, and its all i had at the time (besides CA) it stayed relatively soft for a while, but eventually gets rock hard.
there may be some rubber cement type adhesives that work better
Will there ever be a 1/8th scale Electric onroad car Raydee Oval, Larger Scales and More 1264 03-30-2017 06:47 AM
Opinions need on Kawahara ZAC Project Foam Tires charlesd Nitro On-Road 23 04-24-2007 10:58 AM
GRP Tires jelayne Nitro On-Road 116 04-01-2007 08:10 AM
