Closed Thread
Old 05-02-2004, 03:15 AM   #1
Thumbs up MonoTuning Products
More to come!
Check out TechTips for some speed secret
MonoTuning
monotuning is offline
Old 05-02-2004, 06:07 AM   #2
stefan's Avatar
Send a message via AIM to stefan
Cool, finally an aftermarket exhaust seal that looks like it's going to fit
stefan is offline
Old 05-02-2004, 02:18 PM   #3
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
and 3 per package its even a better deal!
Marcos.J is offline
Old 05-02-2004, 06:05 PM   #4
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
the gasket is pretty good, good value too!
Ah10 is offline
Old 05-04-2004, 10:54 AM   #5
Super Moderator
Marcos.J's Avatar
Hey Aaron ,check out the tires on my Serpent710!!
and another one just in case
Marcos.J is offline
Old 05-04-2004, 10:59 AM   #6
stefan's Avatar
Looks great.
If you just had some Mono stickers )hint hint
stefan is offline
Old 05-04-2004, 11:02 AM   #7
Super Moderator
Marcos.J's Avatar
Looks great.
do you have any??
Marcos.J is offline
Old 05-04-2004, 07:31 PM   #8
Pit-racer's Avatar
Nice wheels .......
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline
Old 05-04-2004, 11:10 PM   #9
Super Moderator
Marcos.J's Avatar
Originally posted by Pit-racer
Nice wheels .......
yes they are!!
Marcos.J is offline
Old 05-07-2004, 04:17 PM   #10
Varuth's Avatar
Default Re: MonoTuning Products
Originally posted by monotuning
More to come!
MonoTuning
what is Monotuening?
Varuth is offline
Old 05-08-2004, 08:27 AM   #11
Super Moderator
Marcos.J's Avatar
Default Re: Re: MonoTuning Products
check out their website www.monotuning.com
Marcos.J is offline
Old 05-10-2004, 07:20 AM   #12
sbmon's Avatar
I tried a pair of these mono tires and was very pleased.
My friend Marcos hooked me up with a set to try of 40 fronts and 37 rears. The car was pushing a little with the harder tire up front so I put on a pair of my usual fast tires in the 37 shore up front (Unfortunately Marcos didn't have any 37 front monos) and then the car felt awesome very planted(with the 37 monos in the rear and the 37 fast tires upfront). I ran these tires for a total of 40 minutes that day and only had 2mm of tire wear on the rear mono tires! With no tire chunking or the slightest wobble and the way I was driving that is saying quite a bit. For me usually the tire wear at that particular track is much much higher especially when running 37 shore tires. In fact my Mugen tends to wear the rear tires quite a bit more at this large track, but the mono rears wore down at the same rate as the fast tires I had on the front of the car, Another bonus is I did not have to true the front tires to compensate for the excessive rear tire wear. All in all I would say these mono tires are excellent tires that have great traction and low wear characteristics, these two traits do not usually coincide in tires but they did for me with the mono tires. I would definitely recommend people give these tires a try. Now if only I could find these tires more readily through local suppliers at the tracks and such these will be a hot items for sure.
sbmon is offline
Old 05-10-2004, 10:07 AM   #13
Super Moderator
Marcos.J's Avatar
Hey Shawn you forgot to say that you won your main and bumped up to the next and ran very well on the other, Im working in getting the local hobby stores in the area to carry Monotuning tires so they should be available to you and to others to use. Well good luck in the next race (Region 4 R.O.A.R Gas On-Road) in June.
Marcos.J is offline
Old 05-10-2004, 12:18 PM   #14
Fire's Avatar
if you use mono's front tires then you need to true them down coz they last even longer than the rear
Fire is offline
Old 05-10-2004, 01:11 PM   #15
John Fontaine's Avatar
Send a message via AIM to John Fontaine
I got 3 pairs of Monotuning tires. They look excelent. Can't wait to try them out this weekend. 40 shore front/back, 26mm F/30mm R. Did you cut them down before you started, say to 63mm?
John
Xray and Serpent....very dusty!
John Fontaine is offline
Closed Thread
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
Looking for KO Products 429racer R/C Items: Wanted to Buy 4 11-30-2004 05:14 PM
Monotuning Tires @ KINETIX RC ATOMIC Nitro On-Road 1 04-01-2004 06:49 AM
