Old 09-26-2004, 06:18 PM   #121
The conversion looks sweet, but how does it drive??? Thats what I want to know!! Can you guys see a positive difference at the track?
PhatPat is offline   Reply With Quote
Old 09-27-2004, 07:56 AM   #122
NiMo's Avatar
I tried it, has good points and bad points, but I prefered the FW05 set up for handling, it's a bit more relaxing to drive hard as you only fight understeer where as the ZT1 would loose the rear for no apparent reason.
FW05 with RRR front hubs is the way to go.
NiMo is offline   Reply With Quote
Old 09-27-2004, 10:42 AM   #123
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default fw
hi al.
nimo, i tend to agree with you,
if you guys can get the new parts for the car,,it will help with the understeering, and yes do use the RRR front and rear hubs..
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 09-27-2004, 11:09 AM   #124
NiMo's Avatar
RRR hub conversion is less than $15.
Old 09-27-2004, 12:34 PM   #125
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
it cost me $12.50!!
Old 09-27-2004, 02:28 PM   #126
Sp Racer's Avatar
NiMo..
RRR front hubs reduce caster ...right?
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 09-27-2004, 03:14 PM   #127
NiMo's Avatar
Originally posted by Sp Racer
NiMo..
Wrong.
It gives more steering angle (smaller turning radius) for the same amount of servo through, and the good bit is....you dont loose any of the rear end grip.
Pictures show mid conversion of front end, left - FW05 hub, Rigt - RRR hub.
Old 09-27-2004, 03:38 PM   #128
rjl
rjl's Avatar
Nigel I think from the way your drive cups broke something must have been snatching in your drive train. My ZT has impeccable manners and goes like the clappers.
Will be run at the Oz Nats this week, I'll report back on the results. At least I won't be looking for bigger pinions.
I'm hoping to get away with 40 shore tyres, everyone else will be on 42-45 to reduce traction roll.
I'm thinking that the slight overdrive with the Kawahara crown wheel and pinion will also be a small advantage.
Personally I'm impressed that Kawahara have taken one look at the FW and made this conversion, speaks heaps about the way he feels about the car.
rjl is offline   Reply With Quote
Old 09-27-2004, 03:46 PM   #129
rjl
rjl's Avatar
I also like the fact that I have more pipes available.
Old 09-27-2004, 03:49 PM   #130
NiMo's Avatar
Nothing was catching, I think it is because i still run 4 wheel braking the extra whip effect on the shaft is too much for the Kawahara cups causing them to shatter, I will look for a stronger item that fits as the Kawahara Diff rings still look like new after 8 meetings and practice days, (that's a good 10 hours of running)
Old 09-27-2004, 03:55 PM   #131
NiMo's Avatar
As you can see on my car, left side NovaRossi pipe fits ok on right side.
Old 09-27-2004, 04:30 PM   #132
rjl
rjl's Avatar
I was thinking of using the drive cups off the FW04 and making a spacer to suit the two speed end.
You should try to run the one way if you're going to foamies, I can out brake most two diff cars.
Old 09-27-2004, 06:48 PM   #133
ATOMIC's Avatar
If anyone wants a ZT-1 that has been run once let me know . I will probably get rid of it for 4 bills with a pipe. Please send any Q's or responses to [email protected]
ATOMIC is offline   Reply With Quote
Old 09-27-2004, 06:49 PM   #134
TRAJ's Avatar
i am VERY interested
i sent you an email
please reply...
TRAJ is offline   Reply With Quote
Old 09-28-2004, 02:43 AM   #135
Sp Racer's Avatar
and what would that be Rob?.....he feels everything is wrong?
[F/S] USED ONCE KAWAHARA ZT CONVERSION + KYOSHO FW05 CHASSIS noobatron R/C Items: For Sale/Trade 3 10-15-2005 07:57 AM
$33 - Kawahara Front Conversion Set For FW-05R cvccsi R/C Items: For Sale/Trade 2 09-05-2004 04:40 PM
Kawahara FW05R Center Conversion cvccsi R/C Items: For Sale/Trade 4 08-09-2004 12:04 PM
Kawahara FW05R Front & Center Conversion cvccsi R/C Items: For Sale/Trade 7 07-11-2004 03:46 PM
Mugen Mtx-2 Kawahara Conversion Kit Pro Models R/C Items: For Sale/Trade 0 12-17-2002 04:42 PM
