Old 04-29-2004, 10:46 AM   #1
How to connect an AMB transponder?
Hi guys,
a friend of mine gave me a little red AMB transponder, but the connector are not on it (he had to cut and I have just 2 wires hanging out now). I wonder where I can hook it up?
Thanks in advance!
Frag is offline   Reply With Quote
Old 04-29-2004, 01:32 PM   #2
Aggdaddy's Avatar
You may have to do a little soldering.
Your best bet is to splice into the throttle servo wire.
You know, red to red and black to black.
Your friend should have told you this too.
Aggdaddy is offline   Reply With Quote
Old 04-29-2004, 01:55 PM   #3
j240z's Avatar
Otherwise you can use a servo connector and plug it into a spare channel on your receiver. This is they way it would come brand new - with the servo connector. I still have the instruction sheet for mine. I will try to post it here.
j240z is offline   Reply With Quote
Old 04-29-2004, 01:57 PM   #4
Do you know if I can buy a Y connector that would split a unique connection in 2 connectors?
That would do a cleaner job.
If not, I will go in soldering. I have no problem with that. I was just wondering where to connect it to not affect any servos.
I already have a fail safe on the throttle link. Do you think that it will affect it?
Old 04-29-2004, 01:59 PM   #5
Ho!!!
That make sense! Do you know if there is always juice on the third channel plug!?
Old 04-29-2004, 02:16 PM   #6
Aggdaddy's Avatar
Oh, I didn't know you had a third channel.
That would be better than putting three devices on one channel.
Just solder on another plug and plug it in. Third channel should be "hot".
I only have two channels on my receiver and I have a fail safe on the throttle. but I spliced into the steering servo for the transponder. Everything works great though.
Old 04-29-2004, 02:21 PM   #7
My transmitter has only 2 channels ...but my receiver on the car is 3 channels ready. It's why I wonder if the 3rd channel plug will be turned on....
Old 04-29-2004, 02:26 PM   #8
Aggdaddy's Avatar
Well the transponder just needs power, and there's no way to turn off a particular channel on the receiver. So I'm pretty sure that it'll be on.
When you apply power to the receiver, everything is on. Your transmitter just sends a signal.
Old 04-29-2004, 02:43 PM   #9
Thanks Aggdaddy!!!
I'll try it for sure (wonder how I will know if the transponder in on a home though) and confirm later.
Thanks again guys!
Old 04-29-2004, 02:53 PM   #10
If it is the small amb red transponder, it will have a small led yellowish light on top when the power is supplied to it properly.
sook is offline   Reply With Quote
Old 04-29-2004, 03:59 PM   #11
j240z's Avatar
YES! if your receiver has power it will power all the channels! And as sook said the yellow led on the transponder will be on!
Old 04-29-2004, 05:53 PM   #12
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Or it will light up green if it's the older version.
Rob Hochberg is offline   Reply With Quote
Old 04-29-2004, 07:09 PM   #13
A little solder and it works in the 3rd plug guys!
Thanks a lot...
Output Batt Connect Error?? Duster_360 Radio and Electronics 1 08-08-2008 05:15 AM
Transponder mff30b R/C Items: For Sale/Trade 3 01-02-2008 07:34 PM
Blue aluminum transponder mount and transponder fat500 R/C Items: For Sale/Trade 2 08-12-2006 07:13 PM
AMB Transponder e420x R/C Items: For Sale/Trade 15 01-01-2005 11:41 AM
My Starter Box Cant Connect With My Np Flywheel! eBoi31 Nitro On-Road 4 04-21-2002 07:35 PM
