Old 05-02-2010, 01:19 PM   #1
ugglasdav's Avatar
Default Centax Clutch
hi there, i am having abit of trouble with my clutch on my 733 at the moment. without the the bearing in the clutch bell and with no shims added anywere, i cant seem to get a bigger Gap then of .20mm. for some reason i cant seem to make the gap bigger. can anybody help me with this problem. the clutch is quite new and the preload is set at 8.72 mm
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 05-02-2010, 02:49 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
How much space is there between the back of the flywheel and the motor? If there is more than just a hair, try a different collet that will allow the flywheel to get closer.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-02-2010, 11:08 PM   #3
or add some(to make 0.7mm need 0.5mm) 3x5mm shim to the end of thrustbearing spacer for extend it.
nsho0l is offline   Reply With Quote
Old 05-02-2010, 11:57 PM   #4
barg's Avatar
Send a message via Yahoo to barg
I had to file down the back of the collet to get the flywheel as close to the engine bearing as possible without it rubbing.
This also helped me line up the first and second gears better left to right.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 05-03-2010, 04:13 AM   #5
How do you measure it?
you can only measure it with a marking gauge!
Because with a clutch tool you touch the 1st gear.
And try to flip 2nd gear, because then the 1ste gear can fit better.
And i have used
Serpent 710/720/733/960/966 Conus Flywheel (3) [SER-6503], this fit better in the flywheel.
good luck
petertjes is offline   Reply With Quote
Old 05-03-2010, 04:47 AM   #6
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
use the right serpent collar you will not have any problems , as you should be able to get .70 gap easily.
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 05-03-2010, 05:53 AM   #7
Which one do you mean??
Old 05-03-2010, 06:38 AM   #8
http://www.serpent.com/product/6503/
Old 05-03-2010, 06:43 AM   #9
ugglasdav's Avatar
hi there i was using a digital calipers to measure the measurments. the measurment between the flywheel and the front bearing is approx 1.55mm. i am using the colet that came with the engine.
>>>Sanwa m11x
Old 05-03-2010, 06:43 AM   #10
the only problem with grinding the wider part / the one that faces the bearing is you have to be dead straight otherwise it will put uneven load on the clutch system hence premature failure of the bearing .
Old 05-03-2010, 06:46 AM   #11
too much it need to be just off the bearing say .10 or .20
Old 05-03-2010, 07:05 AM   #12
ugglasdav's Avatar
i have some spare seprent cones 7mm long will they do?
>>>Sanwa m11x
Old 05-03-2010, 08:19 AM   #13
ugglasdav's Avatar
Problem solved :P
>>>Sanwa m11x
centax clutch ? HELP ! carpet_killa Nitro On-Road 60 10-13-2011 06:38 PM
Mike Swauger's article on setting up a Centax clutch rmdhawaii Nitro On-Road 118 05-30-2008 02:52 PM
Setting up the Centax Clutch the righ way! BeBop Nitro On-Road 18 05-08-2008 04:52 PM
how to install a centax clutch ralliartlanevov Nitro On-Road 6 09-22-2004 01:07 PM
noobie question on Centax clutch kimi Malaysian R/C Racers 6 06-29-2003 08:50 AM
