Old 01-03-2006, 11:12 AM   #796
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Lightbulb
I switched back to my belt driven car. Just felt the CD3 wasn't as fast nor did my engine like the pipe.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-03-2006, 05:55 PM   #797
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Originally Posted by hooked_on
Mcfly:
The diff area is certainly a weak spot on any shaft drive car, it becomes more apparent when you put more power through the chassis. I am currently driving a Kyosho V1RRR and while i dont have any problems with the diff, the belts have a habbit of breaking. I had the pleasure today of pulling down & reassembling the rear end to change the belt
Shaft drive = alot easier to work on
It's times like this i wish i still had a NTC3 or FW05R
H_O
You are spot on there while i dont drive a Shaft drive car and have seen Marty (McFly) suffer many a broken car ths past season it seems to be the case. Shaft drives are very very hard on there drive line and from what i have seen marty wreck the diffs in the CD3 seem to be very small. After you sorted out the engine drama and swapped to the Sirio marty the problem seems to have gotten a bit worse but i could be wrong. Ofna (or Hong Nor as there known here) has got to have a fix for it somewhere
cheers Daniel
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 01-04-2006, 03:39 AM   #798
hooked_on's Avatar
Mcfly:
Out of interest are you using the Pro Kit CD3 with the CNC gears?
H_O
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 01-04-2006, 05:17 AM   #799
& what part of the diff are you guys killing? Crown/Bevel gears or the 6 internal gears?
au_Nightmare is offline   Reply With Quote
Old 01-04-2006, 05:34 AM   #800
Slo-MTX4's Avatar
HO i know that he is using the pro kit for sure. but as far as what gears he is running i am not sure.
Old 01-04-2006, 06:44 AM   #801
Mcfly's Avatar
Hi everyone, i am using the cd3 pro kit i bought 6 months ago, one just the other week the diff sheared the screws off the bevel gear( i know that people are using longer machine screw in the case and i never did that so thats my fault, and that was the longest lasting diff, approx 3 hours of driving, 3 meets and some tuning.) the other about 4 diffs stripped the internal gears, they didnt look too bad just a grove warn on one of the larger gears( 13ti think) and it turned the car into a front wheel drive. can someone explain in detail how to shim up the diff properly in case thats my prob. thanks
Mcfly is offline   Reply With Quote
Old 01-04-2006, 04:12 PM   #802
madbeats's Avatar
Default CD3 Diff info from ofna forum
Posted by Curve Tracer
I have not damaged a diff ... yet, but when building two of them this is what I have done.
1. Assemble the diff (without packing lube) to determine if the gears mesh ok. What I mean is that the parts turn easily by hand. What I have done is substitute the rubber o-ring with one from the shock kit. The combination of these blue/red rubber rings is what I use to set the internal gear mesh. Though it is a pain to assemble and disassemble the diff, it has worked for me.
2. When installing the tapping screws make sure the holes are free of
diff grease (easier said than done) and try a plastic friendly thread locker.
These diff's are not as smooth as my Kyosho GTR car, but the key is to set them up so that there is positive contact (by feeling the operation when it is assembled) but no binding while turning the parts when assembled.[B]
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 01-04-2006, 05:59 PM   #803
hooked_on's Avatar
Ahhhh.... animated boooooooobiesssss
All this talk about diff problems, makes another NTC3 a good option
H_O
Old 01-04-2006, 11:01 PM   #804
Slo-MTX4's Avatar
TC3? I would rather by a FW05-RR as much as i dislike kyosho on-road cars.
Old 01-04-2006, 11:32 PM   #805
Curve tracker might be onto something, Ive had very little problems with he diff but my diff at last meet got chunky/locking up. Inspection seems it was due to the shims wearing out effecting the mesh Installed new shims and all seems fine again (no gears changed) I prolly should of tried extra shims though.........
Old 01-05-2006, 01:47 AM   #806
hooked_on's Avatar
Slo-MTX4:
I had a Fw05-R, and before you hit the track you needed to purchase the Steel Gear (Crown & Pinion), otherwise you had metal filings everywere in only a very short period of time. I am not sure if these gears are standard on the RR version or not though.
H_O
Old 01-05-2006, 01:52 AM   #807
hooked_on's Avatar
Just to check to make sure i am on the right track, you are talking about the actual diff gear itself rather then the crown gear & pinion? I think i need to tak another look at a manul online.
H_O
Old 01-05-2006, 02:34 AM   #808
part # VS002 , manuals online show same gear used in FWO5-R & RR.
Old 01-05-2006, 04:13 AM   #809
hooked_on's Avatar
au_Nightmare:
You are quite the detective
H_O
Old 01-05-2006, 05:00 AM   #810
Slo-MTX4's Avatar
HO you dont race at Brendale do you?
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
