Old 10-08-2005, 08:50 AM   #766
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
On my CD3 pro there seems to be some noise coming from the rear diff or front maybe if you roll the car along the ground. I've already checked and its not from the center diff. Anyone has that noise or it's a shimming issue. When I run the car on my track it sounds like an electric car and nitro running at the same time. LOL. I did fix a problem where the screwed on the steering rack interfered with an outdrive from the front diff. My friend failed to acknownlege that problem so it shaved down the outdrive's exterior slightly. The car doesn't hook up elsewhere that's slippery, but on the track it handles superb.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 10-08-2005, 01:49 PM   #767
Mcfly
Here is my current setup..
body Mazda 6
tyres f/r 37/37 or 40/40 (though anywhere from 35/35 to 45/45 depending on track)
sway bar f/r normally 45deg/45/deg
front hub position 2 (middle hole on knuckle)
caster 1mm
Camber f/r 2/3
springs f/r White/Yellow
toe f/r -1/-2 (I used to run -3deg on rear to help with loose rear but went to -2 to help with more onpower steer)
rear dif oil rear 100k (might help stop chomping ur gears with less diff action, even 1/8 buggies kill diff gears when unloading too much)
front 1 way
ride height 6mm/6mm
shock oil f/r 35wt/35wt
shock piston f/r 2 holes small/2 holes large
shock tower f/r 1/1
lower arm f/r 2/3
Also try adjusting the rear top linkage to the lower hole on the rear hub (less angled arm) See http://p202.ezboard.com/fofnaracingn...picID=38.topic
Also if your centax is just set too high you might be trying to put too much power down? Lots of things you can change, whats your camber settings compard to what im running?
HarKonnenD, my diffs sounded like that when new in the LD3. I just make sure I have the slightest bit of movement between the gears when shimming the diffs.
au_Nightmare is offline   Reply With Quote
Old 10-08-2005, 07:57 PM   #768
HarKonnenD's Avatar
Ok thnx. Stock rear diff is 100k right?
Old 10-08-2005, 08:29 PM   #769
Mcfly's Avatar
thanks au_nightmare ill give your setup a go and let you know how i go.
Mcfly is offline   Reply With Quote
Old 10-08-2005, 10:43 PM   #770
Not sure, mines a LD3 upgrade so it was built a long time ago and dont even remember diff oil? If there was it was replaced with 100k
And dont forget the all important throttle control
Old 10-10-2005, 08:16 PM   #771
Default buying a cd3 pro over a kyosho fw05rr
Thought I would touch bases first with anyone how has a fully optioned cd3 pro? All the aluminum options including alum center shafts. The cd3 pro looks to be a much better deal than the fw05rr but what is the quality like? I like the ultra low-profile layout which should make the cd3 a parking lot terror. I am retiring my rs4-3 and upgrading to another shaft car...
rs4lola is offline   Reply With Quote
Old 10-10-2005, 09:38 PM   #772
HarKonnenD's Avatar
FW05RR is actually a better deal, but the CD3 pro for the price isn't bad as it comes with all the upgrades. I just got the single engine mount as an aftermarket thing. For spare parts might as well get a whole new CD3 Pro kit lol.
Old 10-11-2005, 12:55 AM   #773
IMO FW05 is ugly.
Options I recommend: lower alloy arm holders, alloy sway bar kits, one peice engine mount and alloy steering, spring kit. Use M2x6 or M2x8 machine screws for diff.
Options I am sus on: Carbon/Alloy towers (these heavier? someone correct me), center alloy 2 speed holder (again, is this heavier?)
CD3 is so much better over the LD3 for not picking up rocks in the 2 speed. Mine has spent a bit of time on not so perfect surfaces (chassis looks scratched like a 1/8 buggy) and CD3 pro (0.8) gears last so much longer
Old 10-11-2005, 11:59 AM   #774
HarKonnenD's Avatar
Yeah I like my CD3 pro. I dunno how it would do with say a faster .12 if the rear gear box keeps making that funny noise so it sounds like an elec car. Too bad they don't make solid rears for the car.
Old 10-25-2005, 08:22 PM   #775
SRAD, you got pm. Thanks.
madcat prime is offline   Reply With Quote
Old 10-25-2005, 09:27 PM   #776
MCRUZ's Avatar
Talking GEARBOX NOISE
DONT WORRY ABOUT THE NOISE. IT USUALLY HAPPENS WHEN THE GEARS ARE NEW. ONCE THEY BREAK IN IT SHOULD GO AWAY. MAKE SURE THE SHIMS ARE CORRECT AND THEIRS ENOUGH LUBE IN THE GEAR BOX. MARC
M32EVOX
MCRUZ is offline   Reply With Quote
Old 12-30-2005, 11:51 PM   #777
Bundy_Bear's Avatar
Default Bump!
I can't believe this thread has been dead for almost two months...
Au_Nightmare:
I watched your 1/8th scale videos again today... I have never in my life seen a mini fly so far before
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 12-31-2005, 12:30 AM   #778
hehe yeah I have not recorded any silly stuff for a long time now
All the best for the new year everyone..
Old 12-31-2005, 05:45 AM   #779
hooked_on's Avatar
au_Nightmare:
All good
Have a great New Year and i will annoy in the new year
H_O aka B_B
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 12-31-2005, 10:34 AM   #780
Mcfly's Avatar
Hi everyone, was wondering how your cd3s are going, beating any mugens and kyoshos on any big races?
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
